hello everyone,
i need your help , i am grouping pathitems and text frames in a layer , while looping through pathitems and text frames using for loop , if required pathitem and text frames is found it will group move the group to beginning , but here is the problem so pathitem position is changed so i could miss many pathitems so how to resolve this problem.
for eg
here is my code
function read_create()
for(layer_iteration=0;layer_iteration<layer_file.length;layer_iteration++)
if (layer_file[layer_iteration].locked){
layer_file[layer_iteration].locked=false;
if(layer_file[layer_iteration].name=="NUMBER")
var theGrp =layer_file[layer_iteration].pathItems;
for(var i=0,len1=theGrp.length; i<len1; i++) {
if(theGrp.pathPoints.length == 8)
if(theGrp.stroked == true && theGrp.filled == true) {
var strkColor = new CMYKColor();
strkColor.cyan = Math.round(theGrp.strokeColor.cyan);
strkColor.magenta = Math.round(theGrp.strokeColor.magenta);
strkColor.yellow = Math.round(theGrp.strokeColor.yellow);
strkColor.black = Math.round(theGrp.strokeColor.black);
if(Math.round(theGrp.strokeWidth*25.4/72*10)/10 == 0.3 && strkColor.cyan == magentaColor.cyan && strkColor.magenta == magentaColor.magenta && strkColor.yellow == magentaColor.yellow && strkColor.black == magentaColor.black) {
x=Math.round(theGrp.pathPoints[1].anchor[0]);
y=Math.round(theGrp.pathPoints[3].anchor[1]);
xx=Math.round(theGrp.pathPoints[5].anchor[0]);
xy=Math.round(theGrp.pathPoints[7].anchor[1]);
count=0;
for(text_iteration=0,len=layer_file[layer_iteration].textFrames.length;text_iteration<len;text_iteration++)
if(text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{1}$/) != null||text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{2}$/) != null||text_frame[text_iteration].contents.match(/[A-Z]{1}[0-9]{3}$/) != null){
t=Math.round(text_frame[text_iteration].anchor[1]);
t1=(Math.round(text_frame[text_iteration].anchor[0]))
alert(text_frame[text_iteration].contents);
if(t1>xx&&t1<x){
if(t>y&&t<xy) {
var newGroup = layer_file[layer_iteration].groupItems.add();
newGroup.name = text_frame[text_iteration].contents+":";
theGrp.moveToBeginning(newGroup);
text_frame[text_iteration].moveToBeginning(newGroup);
maybe replace this line:
to that:
theGrp.move(newGroup, ElementPlacement.PLACEATEND);
Try to use reverse loop sorting of items, like this:
for (var i = collection.length - 1; i >= 0; i--) {
var obj = collection;
// some actions
I'm few simplified the code:
Now it is better to read. Should work. Run it in ESTK and catch the errors:
//@target illustrator
read_create(activeDocument.layers);
function read_create(lays) {
var lay_i, txt_i, x, y, xx, xy, count, txtFramesLen, t, t1;
for (lay_i = 0; lay_i < lays.length; lay_i++) {
if (lays[lay_i].locked) lays[lay_i].locked = false;
if (lays[lay_i].name != "NUMBER") continue;
var theGrp = lays[lay_i].pathItems;
for (var i = theGrp.length - 1; i >= 0 ; i--) {
if (theGrp.pathPoints.length != 8) continue;
if (!theGrp.stroked || !theGrp.filled) continue;
if (!(Math.round(theGrp.strokeWidth * 25.4 / 72 * 10) / 10 == 0.3 &&
strkColor.black == magentaColor.black)) {
continue;
x = Math.round(theGrp.pathPoints[1].anchor[0]);
y = Math.round(theGrp.pathPoints[3].anchor[1]);
xx = Math.round(theGrp.pathPoints[5].anchor[0]);
xy = Math.round(theGrp.pathPoints[7].anchor[1]);
count = 0;
txtFramesLen = lays[lay_i].textFrames.length;
for (txt_i = txtFramesLen - 1; txt_i >= 0; txt_i--) {
var text_frame = lays[lay_i].textFrames;
if (!text_frame[txt_i].contents.match(/[A-Z][0-9]{1,3}$/)) continue;
t = Math.round(text_frame[txt_i].anchor[1]);
t1 = (Math.round(text_frame[txt_i].anchor[0]));
alert(text_frame[txt_i].contents);
if (!(t1 > xx && t1 < x)) continue;
if (!(t > y && t < xy)) continue;
var newGroup = lays[lay_i].groupItems.add();
newGroup.name = text_frame[txt_i].contents + ":";
text_frame[txt_i].moveToBeginning(newGroup);
Thank you sir, but pathitems is at beginning , i want text frame should be placed before the pathItem inside the group so textframe will be visible.
to that:
thank you so much!!!
