I want to animate the logo below but when im bringing the logo back to its original form it never loks quite right as im manuallt adjusting each layer.
Is there a way to have all the sections go back to the exact right place without doing this manually on each layer?
The image isnt the final looking logo as al the gaps would be removed. Hope that makes sense ?
Thanks for any help!
I am guessing that you imported your layered AI file as a composition. If that is correct here's the steps that make your project easy.
There you go. There is no reason to not start at the end and move backwards. Whenever I prepare artwork for video in Illustrator I always arrange the artwork in the hero position so that animation is easy. No matter what kind of composite of visual effect you are working on it's usually easier to start laying out the scene on the hero frame and then work backwards and forwards from there.
How do you intend to animate this Illustrator work? Being specific helps. From the looks of the layers, I don't see a whole lot that can be animated.
Hi MattC,
Did you ever finalize this animation? How did you end up doing so? Did any of these responses assist you? Or do you still need help? Please let us know.
Kevin
How did do you animate the anchor points of an AI file? Mine only lets me manipulate them to change the shape but not animate as if the shape changed
