How to Select CTRL + Click command
Engaged ,
Jan 08, 2017 Jan 08, 2017
Hey
Frustrating but I cant find it...
I know there is selection.selectAll but I want to select only pixels in channel so... :
doc.ActiveChannel.select.select < ??
or
doc.channel[5].select.select ??
basically select pixels and then fill layer using selection
Regards
Dariusz
Actions and scripting
619
Adobe
You can load a channel as a selection usinak acyion manager code.  I would also think you coul also add to the selecton by adding accitional channels to the selection.  The Acyion managet load may look something like this:
// ======Load Alpha Channel Selection===============================
function loadAlpha(channel) {
  var idsetd = charIDToTypeID( "setd" );
     var desc2 = new ActionDescriptor();
     var idnull = charIDToTypeID( "null" );
         var ref1 = new ActionReference();
         var idChnl = charIDToTypeID( "Chnl" );
         var idfsel = charIDToTypeID( "fsel" );
         ref1.putProperty( idChnl, idfsel );
     desc2.putReference( idnull, ref1 );
     var idT = charIDToTypeID( "T   " );
         var ref2 = new ActionReference();
         ref2.putName( idChnl, channel );
     desc2.putReference( idT, ref2 );
  executeAction( idsetd, desc2, DialogModes.NO );
JJMack
Engaged ,
Hey
Yeah I know, but I was hoping I could do something like
selectionR = doc.channel[1].select.loadSelection()
selectionG = doc.channel[2].select.loadSelection()
selectionB = doc.channel[3].select.loadSelection()
do stuff with selectionR etc etc. So I can go back to it at will...
Also DOM Selection method:
load (from[, combination][, inverting]) Channel. SelectionType boolean
Loads the selection from the specified channel.
var channelRef = app.activeDocument.channels.getByName("my channel");
SelectionType DIMINISH or EXTEND or INTERSECT or REPLACE
The selection behavior when a selection already exists:
DIMINISH: Remove the selection from the already selected area.
EXTEND: Add the selection to an already selected area.
INTERSECT: Make the selection only the area where the new selection intersects the already selected area.
REPLACE: Replace the selected area.
Used in PathItem.makeSelection(),
Selection.load(), Selection.select(), and  Selection.store().
JJMack
Engaged ,
I have no idea how to use it o.o
Can you throw an example maybe?
Btw thanks for help, many of your posts that I read helped me a lot in past!
I use the Action manager code I posted to load the Alpha channels I have in collage template PSD the Map the Shape Size and image location on image in collages.  The Alpha channels must have the required names.  :"mage 1",  "Image 2", ..., "Image N"
I use the function I posted above. To load the Alpha Channels so I can size position and mask image layers to shape.
loadAlpha("Image " + imageNumber);
JJMack
