Hey
Frustrating but I cant find it...
I know there is selection.selectAll but I want to select only pixels in channel so... :
doc.ActiveChannel.select.select < ??
or
doc.channel[5].select.select ??
basically select pixels and then fill layer using selection
Regards
Dariusz
You can load a channel as a selection usinak acyion manager code. I would also think you coul also add to the selecton by adding accitional channels to the selection. The Acyion managet load may look something like this:
// ======Load Alpha Channel Selection===============================
function loadAlpha(channel) {
var idsetd = charIDToTypeID( "setd" );
var desc2 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
var ref1 = new ActionReference();
var idChnl = charIDToTypeID( "Chnl" );
var idfsel = charIDToTypeID( "fsel" );
ref1.putProperty( idChnl, idfsel );
desc2.putReference( idnull, ref1 );
var idT = charIDToTypeID( "T " );
var ref2 = new ActionReference();
ref2.putName( idChnl, channel );
desc2.putReference( idT, ref2 );
executeAction( idsetd, desc2, DialogModes.NO );
Hey
Yeah I know, but I was hoping I could do something like
selectionR = doc.channel[1].select.loadSelection()
selectionG = doc.channel[2].select.loadSelection()
selectionB = doc.channel[3].select.loadSelection()
do stuff with selectionR etc etc. So I can go back to it at will...
Also DOM Selection method:
load (from[, combination][, inverting]) Channel. SelectionType boolean
Loads the selection from the specified channel.
var channelRef = app.activeDocument.channels.getByName("my channel");
SelectionType DIMINISH or EXTEND or INTERSECT or REPLACE
The selection behavior when a selection already exists:
DIMINISH: Remove the selection from the already selected area.
EXTEND: Add the selection to an already selected area.
INTERSECT: Make the selection only the area where the new selection intersects the already selected area.
REPLACE: Replace the selected area.
Used in PathItem.makeSelection(),
Selection.load(), Selection.select(), and Selection.store().
I have no idea how to use it o.o
Can you throw an example maybe?
Btw thanks for help, many of your posts that I read helped me a lot in past!
I use the Action manager code I posted to load the Alpha channels I have in collage template PSD the Map the Shape Size and image location on image in collages. The Alpha channels must have the required names. :"mage 1", "Image 2", ..., "Image N"
I use the function I posted above. To load the Alpha Channels so I can size position and mask image layers to shape.
loadAlpha("Image " + imageNumber);
