Hello people š
I have 7 buttons on my stage (button1, button2, etc) all MC's. I would like to control the RollOver, RollOut & CLick with js.
At first I thought I could just tell my button Listener where to go
i.e. gotoAndStop(2) which is RollOver state. or gotoAndStop(3) which is Click state. and gotoAndStop(1) which is RollOut state.
But when I "Click" and then rollout, I need the button to stay "clicked" until some other button is "clicked".
i'm trying this but there is something wrong.
// loop through the buttons and give them mouse click listeners
for ( var i:int = 1 ; i <= 7; i++ ){
var curButton:MovieClip = getChildByName ("button"+i);
// set click lisitener
curButton.addEventListener ( MouseEvent.CLICK, buttonClickHandler.bind(this) );
// set rollover listener
curButton.addEventListener ( MouseEvent.ROLLOVER, buttonRollOverHandler.bind(this) );
// set rollout listener
curButton.addEventListener ( MouseEvent.ROLLOUT, buttonRollOutHandler.bind(this) );
// set initial state
curButton.gotoAndStop(1);
function resetStates (){
for ( var i = 1; i<=7; i++){
var curButton = getChildByName("button"+i);
function buttonRollOverHandler ( evt:MouseEvent ){
resetStates();
evt.target.gotoAndStop(2);
function buttonRollOutHandler ( evt:MouseEvent ){
resetStates();
function buttonClickHandler ( evt:MouseEvent ){
resetStates ();
evt.target.gotoAndStop(3);
tnx to all
Okay this unholy mishmash of AS3 and CreateJS APIs needs to stop. This works, assuming the "buttons" are actually movieclips pretending to be buttons:
...this.stop();
// required only if no actual buttons are used
stage.enableMouseOver(20);
// variables
var numButtons = 7;
var i, b, curButton;
// initialize
for (i = 1; i <= numButtons; i++) {
b = this["button" + i];
b.cursor = "pointer";
b.mouseChildren = false;
b.addEventListener("click", buttonClickHandler.bind(b));
b.addEventListener("mou
in your click handler assign a variable indicating evt.currentTarget was the last clicked button. use that variable in resetStates() to determine which to 'reset' and which to not 'reset'.
At a glance, the first thing that's going to cause problems is that you're use AS3 code, not JavaScript. There's no such thing as strict variable typing in JS.
No such thing as getChildByName, either. Instead of:
You'd do:
= this[
"button" + i];
Remember that the CreateJS API that Canvas mode uses is generally more AS2-like than AS3-like. And that frame numbers in Canvas are 0-based, not 1-based.
thanks all for reply
mmmmmmhhh!!! doesn't work...
for (var i = 1 ; i <= 7; i++){
var curButton = new createjs.MovieClip();
this.curButton.getChildByName("button"+i);
i'have tried changing with - this["button"+i] -
curButton is undefined - unexpected type error.
Any suggestion?
in this way there are no errors in consol but
movieclips doesn't listen calls
var button = new createjs.MovieClip();
curButton.getChildByName(button+i);
curButton.addEventListener (MouseEvent.CLICK, buttonClickHandler.bind(this));
curButton.addEventListener (MouseEvent.ROLLOVER, buttonRollOverHandler.bind(this));
curButton.addEventListener (MouseEvent.ROLLOUT, buttonRollOutHandler.bind(this));
//var curButton = ["button"+i];
function buttonRollOverHandler (currentTarget){
resetStates();
function buttonRollOutHandler (currentTarget){
resetStates();
function buttonClickHandler (currentTarget){
resetStates ();
try:
this.clickedButton = null;
this['button'+i].addEventListener (MouseEvent.CLICK, buttonClickHandler.bind(this));
this['button'+i].addEventListener (MouseEvent.ROLLOVER, buttonRollOverHandler.bind(this));
this['button'+i].addEventListener (MouseEvent.ROLLOUT, buttonRollOutHandler.bind(this));
this['button'+i].gotoAndStop(1);
function resetStates (tl){
if(tl.clickedButton!=tl['button'+i]){
tl['button'+i].gotoAndStop(1);
function buttonRollOverHandler (e){
e.currentTarget.gotoAndStop(2);
function buttonRollOutHandler (e){
resetStates(this);
function buttonClickHandler (e){
resetStates (this);
this.clickedButton=e.currentTarget;
e.currentTarget.gotoAndStop(3);
tnx a lot!!!
but...
this.['button'+i].gotoAndStop(1);
return 'missing name after . operator'
š
i'm not sure where that that line of code is, but it should be
this.stop();
// variables
var numButtons = 7;
// initialize
b.addEventListener("mouseover", buttonRollOverHandler.bind(b));
b.addEventListener("mouseout", buttonRollOutHandler.bind(b));
// event handlers
function buttonClickHandler() {
if (curButton) {
curButton.gotoAndStop(0);
this.gotoAndStop(2);
curButton = this;
function buttonRollOverHandler() {
if (this != curButton) {
this.gotoAndStop(1);
function buttonRollOutHandler() {
this.gotoAndStop(0);
yes!!! it works...Tnx a lot ClayUUID...:-)
could you explain a bit your solution pls?
because i have tried to target a specific frame for each button in main timeline but don't work š
in the past i have work a lot with action script 2 but i have a poor knowledge of as3. Sorry for that
I know my question are very basic but pheraps someone find it usefull!
Now that all buttons works properly i'have tried
if (curButton) {
curButton = this;
exportRoot.animazTrade_mc.gotoAndPlay("1");
but all buttons works in the same way calling the same action š
last help!! š
