Hello guys,
I have the view on render and all yet nothing shows on the display monitor. I'm sure it is an easy fix but very confused how I get the effect to show?
here's a comprehensive page on shatter effect where will find professional tutorials from respected authors: http://www.provideocoalition.com/shatter-glass-in-after-effects/
here's the adobe help files about shatter:
https://helpx.adobe.com/after-effects/using/simulation-effects.html#shatter_effect
as for your setup - it appears you have trimmed your text layer
as M said, shatter will start at the beginning of each layer so you should trim it back to the beginning. just drag the beginning edge of
...Copy link to clipboard
It's working correctly. Shatter simulations always start at the beginning and at the place where you parked your current time indicator the pieces already have fallen off the canvas. You need to animate the strengts of the forces to get a different timing or work with split layers.
Mylenium
it doesn't show at all throughout? where and what do I need to change? where is it on the canvas because ive scrolled throughout and it doesn't show?
as M said, shatter will start at the beginning of each layer so you should trim it back to the beginning. just drag the beginning edge of the layer to the start of your timeline. or you can always start over and create a new text layer only this time don't trim it at a further point in time.
i am trying to open the shatter effect in After effect but I can't see this in effects preset panel can you suggest to me what I can do for the situation for the open shatter effect?
