I had a C# code using the C# COM Libraries to extract text from INDD files and am porting it to JSX. It is fully working, except that the output from both does not match entirely. From C# I am apparently able to access more TextFrames than from JS. Coincidently, the text from the TextFrames I cannot access start with the character 0x16.
Has anyone had a similar issue?
Thanks in advance.
PS: I am using InDesign Server CC 2014.
Internally both JS and COM use the same hooks, so you should get the same results. Can you post your code?
