I can't change a photo colour like it"s showed here InDesign - Quick-Color That Grayscale Photo - YouTube ?
I can change only a colour under the photo in the container.When I am picking up a direct tool and the frame is brown when the photo is active not container the palette colour is getting non active?
And you must be on fill; not stroke. Also, the image must be grayscale mode.
The grayscale also has to have a non transparent bottom layer (Background in PS)
Thx guys, I didn't save it in the grayscale now it's ok.
Is it possible to use a cat out object with transparent background and put on it a colour?
I want to do something like in PS when you are putting a photo in to a shape and cover it with a colour layer.
With everything you're trying to do, I'd pop over to Photoshop and do it. Way easier than jumping through hoops in InDesign.
Sure. You can place an image with a transparent background in or over a frame with a colorful background.
I think the OP wants to apply a color to the image in ID, so it has to be a grayscale or Bitmap with a flattened bottom layer—no cut out. There could be a clipping path.
I think you are right. I read "put on it a color" as "put it on a colour".
