Hi everybody!
I have an Indesign document of 5000 pages (its for a coupon block with univocal codes), with these dimensions 15,5x4,5 cm.
I would like to put as many pages (single coupon) as possibile for each page inside a new Indesign document to optimize the printable final file (pdf).
The only solution I have found is creating a grid inside the new document, for example an A4 with 6 spaces, with empty rectangles, and then import all pages from the original multi-page file, clic each rectangle to put in the single coupon, and than use "command+alt+C" to adapt the content. The final result is what I want but I have to do this 5000 times.
There is any faster or automatic way to do this?
I have found this fast solution:
1. Export the pdf and than take all pages out of it as single pages (as suggested by Willi Adelberger, thanks again).
2. Create a .csv with the path of each pdf (one per row).
3. Create a new InDesign file, place inside the master page an empty rectangle with the dimension of the element (in my case 15,5x4,5cm).
4. Open data merge panel and select the .csv. Assign the linked pdf to the rectangle e than create the new document with the button inside data merge panel.
...Copy link to clipboard
Normally it would be possible to make a grid with the arrow keys, but with multiple page PDFs (and INDD are as such placed) it is not possible.
I would recommend an easy workaround:
I am sure it could be scripted, but if you want to do it only once, it will be faster that way.
Thank you for your answer!
I know this method and I have tried it now, but is not faster than my method (creating the empty rectangles and clic to put each page inside) and I feel more confortable with it. I have to do it for each page also in this case.
Thanks anyway!
Try the tips and suggestions here http://indesignsecrets.com/quickly-place-images-indesign-document.php​ - some of these i have already tried and used successfully.
Credit should go to the person who wrote this article though
4. Open data merge panel and select the .csv. Assign the linked pdf to the rectangle e than create the new document with the button inside data merge panel. Select the 'multiple record' (I don't know how it's called in english version), set your layout and clic ok. InDesign will create a brand new document with all your pdf throw the pages based on layout settings choosen before.
Thanks everyone for help!
No problem. Please either mark correct answer or mark as assumed answered
