hello,
When I place Image in indesign the quality of the image is bad ?
how I can place the image with the same orif=gnal quality
what do you have set under Display Performance in Preferences?
Are you sure?
Try this -
And read this -
http://indesignsecrets.com/high-res-image-look-low-res.php
Indesign uses preview, regardless of image resolution.
Go View>Display performance > High Quality.
regards
Vinny
I did, it is stay the same
Forgive these basic checks:
IF all else fails have you tried resetting all of your InDesign preferences stored on the computer?
The display performance is high quality
What's the effective PPI of the image (located in the lower half of the Links panel with the image/frame selected)?
Actual PPI:72
72 is not a high resolution, so it will not look smooth, even not on a screen as screens have now much higher resolution.
effective PPI:79x80
Not high neither, don't expect high quality with that grasp.
so what to do?
Edit the resolution of the image in its respective programme (either photoshop or illustrator) and resize the image resolution to min 150 or best 300 PPI.
Also proportionally increase the width to min 500 pixels or max 1000 to look good on most finished product results.
This is an example of a relatively good width and PPI which I would use:
Upsampling in Photoshop cannot create information that was not there to begin with; this won't help the blurriness or quality of the image.
True. But it will at least enhance a bad picture to possibly the level required. If the image looks still too bad then simply another image must be used or the supplier of the image should be contacted to see if it is possible to obtain a better quality version of the image.
Of course - that's why it helps if you take your own pictures.
I tried large image and small one I also enhanced the resolution
the original the gray one and then what i did export the original and edited in photoshop then placed it
