Is it possible to batch print psds? If so, how? Thanks!
Put the files in a specific folder.
Create a Print Action - Simply record a new action and print a file. Be sure to include a "Close" in the action.
Then from the File menu... Automate > Batch...
Choose the folder of images. Click OK.
Each image will open and be sent to the printer then close.
If your photoshop print default setting are correct you may able to record a single step action Pint one copy and batch that action
In addition:
If you are not using the same settings for each file you can set that uno in the following way. While the file is open invoke the print dialog, set all the parameters necessary and click Done. Close the file and save.
Now when you run the action for the batch the settings applied to the file will be used regardless of what was printed prior. For example, some images can be printed with indicators or scaling or different profiles.
