21 Replies Latest reply on May 30, 2018 2:40 AM by poi-oezd Branched from an earlier discussion.
    Installer issue with exit code 191
    samuellaycock
      I've tried installing on Windows 10 but keep getting a failed install at 49% with this error:
      Exit Code: 191
      -------------------------------------- Summary --------------------------------------
      - 2 fatal error(s), 2 error(s), 0 warnings(s)
      FATAL: Error (Code = 191) executing in command 'AddUWPAppxCommand' for package: 'UWPAssets', version:0.6.8.6
      FATAL: Error occurred in install of package (Name: UWPAssets Version: 0.6.8.6). Error code: '191'
      ERROR: hdhelper exe at C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\HDHelper.exe failed to install UWP app with xml
      Adobe.CC.XD
      C:\adobeTemp\ETRD474.tmp\1\SparklerApp\SparklerApp.appxbundle
      0.6.8.6
      x64
      CN=Adobe Systems Incorporated, OU=Adobe Systems, O=Adobe Systems Incorporated, L=San Jose, S=California, C=US, SERIALNUMBER=2748129, OID.2.5.4.15=Private Organization, OID.1.3.6.1.4.1.311.60.2.1.2=Delaware, OID.1.3.6.1.4.1.311.60.2.1.3=US
      adbxd:
      Microsoft.VCLibs.140.00
      14.0.24123.0
      x64
      CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US
      C:\adobeTemp\ETRD474.tmp\1\SparklerApp\Dependencies\x64\Microsoft.VCLibs.x64.14.00.appx
      false
      with error code -1073741819
      ERROR: Failed to install UWP Appx Package
      I've seen suggestions that its might be to do with not having the Anniversary update, however I have this installed up to the most recent release. Any light on why this error is happening?
        • 1. Re: Installer issue with exit code 191
          elainecc Adobe Employee
          Hey samuellaycock-
          It looks like it's a general problem with installing UWP applications on your machine and not with XD in particular. I'm going to move this question into the Creative Cloud installer forum to get our experts on the case.
          -Elaine
          1 person found this helpful
          • 2. Re: Installer issue with exit code 191
            Jeff A Wright Adobe Employee
            Samuellaycock what process are you using to install XD?  Are you utilizing the steps listed in Download and install Creative Cloud apps ?
            • 3. Re: Installer issue with exit code 191
              pppppp58601036 Level 1
              I got the same error. How to fix it?
              My system: Windows 10 Enterprise 14393.576 / x64
              Exit Code: 191
              -------------------------------------- Summary -------------------------------------- -
              2 fatal error(s), 2 error(s), 0 warnings(s) FATAL: Error (Code = 191) executing in command 'AddUWPAppxCommand' for package: 'UWPAssets', version:0.6.8.6 FATAL: Error occurred in install of package (Name: UWPAssets Version: 0.6.8.6). Error code: '191' ERROR: hdhelper exe at C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\HDHelper.exe failed to install UWP app with xml Adobe.CC.XD C:\adobeTemp\ETRF30E.tmp\1\SparklerApp\SparklerApp.appxbundle 0.6.8.6 x64 CN=Adobe Systems Incorporated, OU=Adobe Systems, O=Adobe Systems Incorporated, L=San Jose, S=California, C=US,
              OID.1.3.6.1.4.1.311.60.2.1.3=US adbxd: Microsoft.VCLibs.140.00 14.0.24123.0 x64 CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US C:\adobeTemp\ETRF30E.tmp\1\SparklerApp\Dependencies\x64\Microsoft.VCLibs.x64.14.00.appx false with error code 1 ERROR: Failed to install UWP Appx Package
              • 4. Re: Installer issue with exit code 191
                samuellaycock Level 1
                Yeah, I'm installing through the Creative Cloud app.
                Just for reference, it's not a problem with UWP apps in general as I've installed some today as a test, and no errors for any of them.
                • 5. Re: Installer issue with exit code 191
                  Guilherme Harrison
                  Yeah, I have the same problem installing from the CC app. I'm running windows 10 on a small ssd and configured things to be installed at a different drive, if that's useful information.
                  Exit Code: 191
                  Adobe.CC.XD
                  D:\adobeTemp\ETR5820.tmp\1\SparklerApp\SparklerApp.appxbundle
                  0.6.8.6
                  x64
                  adbxd:
                  14.0.24123.0
                  x64
                  D:\adobeTemp\ETR5820.tmp\1\SparklerApp\Dependencies\x64\Microsoft.VCLibs.x64.14.00.appx
                  false
                  with error code 1
                  • 6. Re: Installer issue with exit code 191
                    Samuellaycock are you also attempting to install to a custom location?  Have you adjusted any of the Environmental variables for Windows 10 such as the location of the temp directory?
                    If so I would recommend reverting to installing to the Program Files directory to see if XD then installs successfully.  If you continue to face difficulties, and you have modified the location of the Temp directory then you may also want to revert to storing the data on your C: drive to see if this then allows for a successful installation.
                    Finally if you continue to face difficulties, or have not customized the install location or the temp directory, then I would recommend installing XD on a newly created local administrator account.  You can find complete details on how to set up a new account at Adobe troubleshooting: Creating an admin account in Windows .
                    2 people found this helpful
                    • 7. Re: Installer issue with exit code 191
                      sam.am Level 5
                      In addition, could you please check if windows firewall service is enabled in services.
                      Open Run command and type services.msc
                      Bottom side find windows firewall
                      Right click and open properties
                      If it is diabled, then change it to automatic and start the service.
                      • 8. Re: Installer issue with exit code 191
                        I checked on two computers (Windows 10 Enterprise 14393.576 / x64). Methods do not work...
                        • 9. Re: Installer issue with exit code 191
                          johnz57054441
                          Same problem here. Additionally, found this in the
                          event logs (Microsoft-Windows-AppXDeploymentServer/Operational):
                          error 0xC000003A: Deployment of package Adobe.CC.XD_0.6.8.6_neutral_split.scale-100_adky2gkssdxte was blocked by AppLocker.
                          and
                          Deployment Add operation with target volume C: on Package Adobe.CC.XD_2016.1203.415.0_neutral_~_adky2gkssdxte from:  (SparklerApp.appxbundle)  failed with error 0xC000003A. See http://go.microsoft.com/fwlink/?LinkId=235160 for help diagnosing app deployment issues.
                          and
                          AppX Deployment operation failed for package Adobe.CC.XD_2016.1203.415.0_neutral_~_adky2gkssdxte with error 0x80073CF9. The specific error text for this failure is: error 0xC000003A: Deployment of package Adobe.CC.XD_0.6.8.6_neutral_split.scale-100_adky2gkssdxte was blocked by AppLocker.
                          • 10. Re: Installer issue with exit code 191
                            Hey johnz57054441-
                            So it looks like your corporate IT policy is blocking you from installing Adobe XD using a product called AppLocker. Here's an article I found on it: AppLocker (Windows 10)
                            You might want to check with your IT department to see if you can get your machine unlocked or Adobe added as an approved publisher to install.
                            -Elaine
                            • 11. Re: Installer issue with exit code 191
                              johnz57054441 Level 1
                              Thank you Elaine,
                              I've been checking many options last night during which I found out that actually no updates or installs from the Windows Store are (allowed to be) installed. So I did a Win10 update which worked but still no Store installations.
                              So I can report that it is not a problem with Adobe XD only, it is a system-wide problem (in my case).
                              I will let you know if I find a solution.
                              John
                              • 12. Re: Installer issue with exit code 191
                                cielazure
                                Just start the Windows Firewall service and the installer works! It would be disabled by default if installed another security software like Kaspersky and it would prevent the update of XD. Not sure how the installer relates to the Windows Firewall but the fact sounds a bit annoying.
                                • 13. Re: Installer issue with exit code 191
                                  Thanks for sharing your solution!
                                  -Elaine
                                  • 14. Re: Installer issue with exit code 191
                                    gvcgaesco Level 1
                                    Hey, guys, I had this problem for 3 months I was in trouble because I needed the software for a big project and I did the recommendation to use Adobe XD to the product owner, and the software didn't work the people in Adobe doesnt know anything about this error ( I think this is a shame). I solve it this way.
                                    • 15. Re: Installer issue with exit code 191
                                      nzdude
                                      I initially added an AppLocker Package app rule rule to allow:
                                      Publisher:
                                      Package name:
                                      Package version:
                                      * [and above]
                                      But that did not work for me.  The publisher is clearly not correct.
                                      The way I found the correct publisher string was to use another PC that didn't have AppLocker applied, install the app, then fire up the local group policy editor, navigate to Computer Configuration > Policies > Windows Settings > Security Settings > Application Control Policies > AppLocker > Packages app Rules, and add a new rule, browsing to the app.  You can then copy and paste the Publisher into your enterprise's Group Policy.
                                      Here's what I found:
                                      CN=Adobe Systems Incorporated, OU=Adobe Systems, O=Adobe Systems Incorporated, L=San Jose, S=California, C=US, SERIALNUMBER=xxxxxx, OID.2.5.4.15=Private Organization, OID.1.3.6.1.4.1.311.60.2.1.2=Delaware, OID.1.3.6.1.4.1.311.60.2.1.3=US
                                      Not sure if the serial number is unique to us, so I've changed it to xxxxxx.
                                      • 16. Re: Installer issue with exit code 191
                                        keithw87208203 Level 1
                                        Done this several times and had two Adobe "technicians!!" try without success? This method dosnt work!!
                                        • 17. Re: Installer issue with exit code 191
                                          Massive problem, had several Adobe Tech's look at it three times with no success - I eventually sorted it myself.
                                          1.) Have the latest OS update: PC or MAC
                                          2.) Simply switch off all internet protection for the duration of the install.
                                          That Adobe haven't spotted this in over a year beggars!!
                                          Best
                                          • 18. Re: Installer issue with exit code 191
                                            Recluse.Nick
                                            I met the same problem and have been solved!
                                            Some system services were disabled before, so I started these services again!
                                            You can install it, no further error!
                                            我遇到了同样的问题,已经得到解决!
                                            之前禁用了一些系统服务,所以我重新开启了这些服务!
                                            可以安装了,没再提示错误!
                                            • 19. Re: Installer issue with exit code 191
                                              reniers52995531 Level 1
                                              This one made the trick for me. Just for the record, I'm under corporate network too.
