Hello,
how can I create a protected pdf with not write-protected elements out of word 2013? The elements should be already created in word and still available for filling out after pfd converting. (Should be started from developer tools in Word - in german subfolder "Formulare aus Vorversionen"?!)
Thank you very much in advance.
What kind of protection do you want to apply to it?
After converting only copyfunction out of pdf should be allowed .
In Acrobat go to File - Properties - Security and select "Password Security". Then in the window that opens select to restrict editing, but under Changes Allowed select "Filling in form fields and signing existing signature fields". Then tick the "Enable copying to text, images and other content box", click OK, enter your password and save the file.
If you talking about form fields, Word cannot create a form with Word form field objects tht wii convert to PDF form fields. To do this you need you need to use OpenOffice or Libre Office. You should apply protection agter you add form fields, field, options, and interactive actoons.
