Hello,
I bought a Lightroom + Photoshop license. I installed both software easily. My problem is: I can not export photos from Lightroom to photoshop with the context menu (photoshop appears grayed out) and I can not export as a dynamic object, merge HDR or panoramic. What should be done to establish the link between the two programs
thank you in advance for your help
EDIT [moved to correct forum – moderator]
There are lot of threads about this issue here in this forum.
Take a look here: https://forums.adobe.com/thread/1989804
Thank you Axel!I will see if I find an answer on this forum
Hello,
I found on the forum indicated how to solve my problem, but I'm worried about changing the registry as explained... The other solution would be to uninstall Photoshop and reinstall it!
My problem is that I installed Photoshop directly from the "Creative Claoud", I do not have a copy of the program! Is it possible to download it with my license again?
Thank you in advance for your help
I changed the registry as explained, but it has not changed, I still have the same problem. I can not uninstall photoshop from my PC, it does not appear in the list of programs, only Creative Claoud! Should it uninstall any creative cloud? Will I be able to reinstall with my license?
Moving to Photoshop General Discussion​
And thank you Bani!
