Paragraph separation too great
Jan 11, 2017 Jan 11, 2017
I was working in an InDesign file yesterday, and all was well.  Today, if I hit the return button, all the text below is moved into a paragraph that cannot be seen.  The frame now indicates that I have text outside the size of the frame. No matter how big I make the frame, the text does not appear.  Even the frames I filled in with text yesterday are doing this today.  What did I do?
805
Mentor , Jan 12, 2017 Jan 12, 2017
Try Fn+Return combination then.
Edit: also you may find interesting to read this thread.
It will help if you open up the Story Editor (Edit > Edit in Story Editor) when you have your cursor in the story. You may be able to see a "break character" or something that is keeping the text from showing.
Nope, that doesn't help.  Story Editor indicates that there is an overset as soon as I hit the return, but doesn't show any special character or space. When I return to the document, the text below the return is now all below the visible area of the frame, and the frame has a big empty space.
Thanks, though.  Story Editor will be helpful in other ways.
Maybe your paragraph style has an accidentally giant space-after or space-before amount? Or if you were not using styles, maybe the default amount in the Control Panel is accidentally set too great an amount?
Mike Witherell
Mentor ,
Which Enter key do you use? Enter on a main keyboard makes new paragraph. By hitting Enter key on the numeric keypad, you create a column break. If there's just one column in a frame, your text jumps to the next threaded frame. If there isn't such, your text is overset.
I mean, use the "green" one:
That's what I would have said, if you hadn't beaten me to it, Winterm!
Mentor ,
Ah, "Ladies first", I was taught... I'm so awfully sorry, Barb!
LOL!
OK, this is leading us closer to the solution.  I am back in the office today and working on a keyboard.  What you say above is exactly true.  If I use the return key on the main keyboard, I have no issue.  If I use the return key on the number pad, I have the issue described.
However, yesterday, I was working on my laptop which does not have a number pad.  The return key on the main keyboard was acting like the return key on a number pad.
I am using Creative Cloud, and it says all apps are up-to-date.
Mentor ,
Jan 17, 2017 Jan 17, 2017
I don't know why my laptop is giving me the keypad return, but Fn+Return solves the problem.
Guide ,
Hi
Story editor can (again, yes! ^^) help you out here...
Set invisible characters ON and have a look at the symbol shown in the story editor, just before the excess separator.
which one is it:
If its "normal" return, did you check premio_oscar​ suggestion?
Don't forget screenshots are usually very helpful... maybe you can share some
regards
Guide ,
check this option:
paragraph style options > keep options > start paragraph
choose "Anywhere"
It would also good to know which version are you using. Due to a bug in 2 versions in the past (CS5 several languages, CS6 Swedish) the return key was tagged to the enter key. This could be repaired simply by an update.
interesting … the more common problem is hyphenation turned off and a word is too long for the display area … thanks for that article!
