I have never bothered using the Smart Publishing Wizard but I
just set up a couple and can see how it works.
What I cannot see is how you are simultaneouslyy running four
profiles from the SPW.
You select one from the dropdown, run it and when finished
start over.
Explain that and maybe I can replicate your problem.
Also under SSLs, how are you generating four at the same
time?
