Hallo
seit dem Update kann ich nichts mehr exportieren. Speichern unter geht, aber exportieren kann ich nichts mehr.
Hat jemand das gleiche Problem und am besten noch eine Lösung für mich?
Vielen Dank
Der Jan
Please try restoring Ps Preferences following Preferences in Photoshop and let us know if that helps.
~Akash
Hey ich habe das selbe Problem! Leider auch noch keine Lösung. wäre auch sehr dankbar wen jemand ne Lösung parat hat. Wollte ner Kundin ihren Gewerbeflyerentwurf gerade als JPG rüberschicken, aber bei ,,Schnell-Export als JPG" passiert nichts. Und ,,Exportieren als..." läd das fenster ins unendliche
Hi jaynai,
What exactly is the error message you get when you export and what size are the images?
Akash
Akash SharmaAn error occured while performing this operation. Contact an administrator of this problem continues This is what we see when we want to export a pic. But it doesn't go on....
~Akash
wont work. any registry entries to delete???
That doesn´t help Akash Sharma
what can be the next step to solve this issue. Quick-export is possible, but export-as fails.
br
Sven
It Works. Thaks Akash Sharma
Is the problem solved?
I have the same problem.
No export.
I try to restore the PS preferences, but it is still the same.
I still deinstalled PS.
Some more options?
Same problem here. Seems like a runtime error. Tried deinstall/reinstall without prefs. Maybe there are registry entries to delete? pls help asap!!!
Unfortunately this function (export as...) needs obviously an active internet connection bc I as I did deactivate the inet adapter it wrks fine.
1st: WTF adobe!?? R u guys serious??
2nd: Tell me the effin port(s) to forward that I can configure the proxy right.
3rd: Do it quickly!!!!
