I haven't used Lightroom for awhile and I'm trying to finish a phonebook I started. I finally figured out that the list of modules that is usually along the top right is missing on my screen (Library, Develop, Map, Book, etc.). The only way I can select a different module is to go to 'Window' and scroll down to the module I want there. How can I get these to show up again? It's just black space where they're supposed to be.
Please note the small triangle on top middle, actually on all sides. Click on it and right-click on it to see the options.
Also try what happens when you hit Shift+Tab or Tab ​- very useful shortcuts.
Also in addition to above answer- If you have any module visible on the top row, you can right-click on a module name and tick/check to select which of the module names you want to show (or hide).
Example: If you never use Maps you can uncheck "Maps" and hide it on the module menu strip.
i have the same poblem. no modules on top right. But, also no triangles. Please help
By @defaultklervv6x023p
Could you give us a little more information, please? Like these items:
I have the same problem, I just installed Lightroom and cannot find how to print a picture - incredible oversight as it's not in any menu and even not in help. Shouldn't systems have intuitive navigating? I can not find 'little triangles' to hunt for a basic function of a picture program (to print the picture).
Please help (btw, I installed Lighroom because Photoshop has no function to print 2 pictures of an exact size (13x18cm) to one sheet of paper. Was told Lightroom would have this function)
Lightroom version 5.2
Windows 11
You need Lightroom Classic, not Lightroom. Different application with more pro features including printing.
