When I'm using After Effects to edit 360 degree video using purchased template, it automatically shuts down. Is it because of the software or my Mac configurations?
Model: Macmini7,1, BootROM MM71.0220.B08, 2 processors, Intel Core i7, 3 GHz, 16 GB, SMC 2.24f32
Graphics: Intel Iris, Intel Iris, Built-In
Without any info on the template you are referring to nobody can tell you much.
Mylenium
haha. ok. The template I brought is...
360° Video Editor (After Effect project)
Add to your stitched 360° video text, logo, effects, masks, do object removal or motion-tracking, shape animation, add 3d objects, including support plug-ins (Trapcode Particular and Form, Element 3D, Plexus, FreeForm, FreeForm Pro, mettle ShapeShifter Ae, Zaxwerks etc.) and export into 360° format once again.
Well, is there any plug-in out there left that the template doesn't use? Let me be blunt: This is probably simply because someone went trigger-happy on using every third-party plug-in he owned and you are simply seeing resource conflicts or running out. That aside, a link to the actual template would be more useful than listing all that stuff.
Mylenium
Ok. Here's the link to the template:
It says it doesn't require any plugins. Thank you for your time to answer my questions!
I see that this thing works with AE CS6 thru 2015. NO MENTION is ever made of AE CC 2017. What version of AE are you running?
I also see the thing comes with a tutorial. Have you used it?
Hi AliciaH,
Did you ever solve this problem? Did the tutorial or any of the advice here help you? Please let us know how things turned out and how you solved your problem.
Kevin
