I had the following problems when installing the PProPanel example extension
for use on w10, PPro 2017
(version is <Extension Id="com.adobe.PProPanel" Version="10.3.0" />)
1. The ReadMe.cmd says to put the extension directory in
"`C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\PanelDir`"
When I did that it PPro did not find the extension
It did when I put it in
C:\Program Files\Adobe\Adobe Premiere Pro CC 2017\CEP\extension
2. The css file was not being read, so that the text was not visible I had to add the following to the index.html file
<LINK href="css/style.css" rel="stylesheet" type="text/css">
Are these bugs or is there something wrong in my setup ?
I want to create something that will work on 2015 and on 2017 - which example PProPanel and which CEP should I be using ?
'PanelDir' was intended to imply your panel's directory; in your case, PProPanel. Glad you sorted it out.
Yes, PProPanel doesn't care much about style sheets.
PProPanel is the right sample for all versions of PPro; 10.4 and 11.0 (2015 and 2017) both support CEP 6.1.
