I am trying to have a box that when moused over, pops up additional text.
I think I have my settings correct...the additional text (button 2) is in its own box and is converted to a button with "Hidden Until Triggered" selected. The original box of text (button 1) is also converted to a button and has these events added:
It works perfectly in the preview. When I export to a .pdf with the Interactive Elements: Include Appearance and Hyperlinks both selected...it doesn't work. Button 2 is showing and does not change at all when button 1 is moused over.
Any suggestions? Help please!!! (I am on Adobe CC, everything is updated)
Use File > Export > Adobe PDF (Interactive) instead of PDF (Print). Print PDFs don't support buttons and more advanced interactivity.
I knew it had to be one tiny thing...thank you SO much!!!! You have helped me immensely.
So that solution worked for you?
Yes, your solution helped. Thank you!
Maybe you can help with this also...button 2 is showing up behind button 1. I need it to be in front. Do I need to turn on layers in the .pdf export? In the .indd file, button 2 is in front of button 1.
Unfortunately, I'm having a very busy day today. I'll be unable to further help you, but we have a lot of other experts here who I'm sure can jump in to help.
