Hello,
Since the 6.8 update, I have a very annoying bug in my Lightroom. In the Library, when I press the key "X" to tag a picture as rejected, it doesn't work anymore. Despite of that, it masks the numbers of the pictures in the folder when I press the key. On the other hand, the key "P" to tag a picture as marked, works fine... very strange
And when I am in the "develop" module, both keys "X" and "P" works ... but it's very slower than in the library module, and far less convenient.
Any idea of what I could do to fix that ? Am I the only one to have this bug since 6.8 update ?
Many thanks to all for your answers and help,
Best regards
Felix
Hi Felix,
Please update Lightroom to 6.9/2015.9 version which includes the fix for Lightroom CC 2015.8: Shortcut X to reject an image in Library not available (French) | Photoshop Family Customer Communi…
refer: Lightroom CC 2015.9 now available
Mohit
Do you have any keyboard add-on program installed?
Have you made any changes to the language keyboard setting in the OS you are using?
What is the OS you are using?
In which language are you running LR? French and Swedish have known problems with the "x" shortcut:
If you're in one of those languages, see the appropriate topic for a workaround and add your me-too vote and opinion to that topic. If you're in a different language, please report it here.
I have the same problem. I have no keyboard add-on programme. And, yes, I use a French keyboard
Bonjour,
J'ai le meme problème que toi et j'ai contacté le support adobe par chat ce matin meme. Il semble que cette modification ne soit pas un bug... Ce qui est très embêtant au quotidien ! As-tu eu une autre réponse/solution ?
I think Adobe support is giving out incorrect answers. Adobe marked the bug report in the official Adobe feedback forum as "In Progress", meaning they've acknowledge the bug and are working on a solution. Meanwhile, see this post in that bug report for how to work around the problem while waiting for a fix: Lightroom CC 2015.8: Shortcut X to reject an image in Library not available (French) | Photoshop Fam...
Hi Felix,
Please update Lightroom to 6.9/2015.9 version which includes the fix for Lightroom CC 2015.8: Shortcut X to reject an image in Library not available (French) | Photoshop Fam...
Mohit
