I want the ability to scale evenly ("maintain aspect ratio") using the top, bottom, left or right transform points — not the corner points.
In Illustrator, I can do this by holding the shift key while click+dragging. In Photoshop, this only works when using the corner transform points. Is there a good reason for this? Or is it a bug?
Hi
PS and AI are two different software created by two different engineers teams.
Wonder why this is bothering you.
Pierre
Hi
Pierre
Of course. I don't know about Illustrator, but with Photoshop, the various modifier key / handle combinations all have different functions. You can scale while maintaining aspect ratio with the corner key, and scale symmetrically by adding the Alt key. Shift dragging a mid point handle scales just width or height, but keeps things nice and square (prevents skew). That is immensely useful.
There are too many options to list them all, but go try Free Transforming a square object via its corner and mid handles and try all combinations of Shift Alt Ctrl (Shift Opt Cmd).
I see no difference between shift+dragging a midpoint and simply dragging a midpoint. Do you?
Shift+drag should mean proportional scaling regardless of anchor point.
Hi
Not in my version of illustrator. ( Illustrator CC 2015.3 ). It work as in PS.
Pierre
Upgrade your software, bruh.
2017 lets me shift+drag any anchor point to scale proportionally.
