When I print a photo on my Epson SC-P800 the location on the paper is wrong.
The photo is shifted 94 mm to the right and 60 mm up
This does only happen when printing from Lightroom and not when printing from PS
Below are a sketch of the printing
What can cause this problem ?
Equipment - iMac, latest operating system (Sierra 10.12.2) and Epson printdriver
Best regards
Soren N
Post a Screen Shot of the print module showing all of the setting you have selected.
Here are the screenshot
It is more than likely a paper orientation problem. Your screen shot shows you have LR set (and or the printer properties set) to landscape orientation. How is the paper feed into the printer, landscape or portrait orientation.
And if I may ask why are you using A4 paper to print such a small image?
No, its defenitly not a paper orientation problem - I know what I'm doing in that respect, I have been printing on a 3880 and the P800 for last 8 years.
I'm not normally printing this square on an A4 page - this is done not to ease a lot of ink when you print multiple test prints.
There is a difference if I print to the printer or I print to a jpg file
se the to below
print to jpg
print to printer
had same image issue
went to the LR cc classic print page and did custom and played with border.. it at least is the correct orientation now..
doesn't seem to like 11 x 17
p800 epson
i will try to do borderless next testing get pricy at 11 x 17 though
from
Matthew
Missing a decent reply of what the cause could be.
So far no good answer to my request.
Why can I print ok i PS and not in LR without shift to the right an up ?
