Before:
After:
… One light-saber hit! …
… Nothing seems to have happened!
Just use The Force!
Script wrtitten by Michel Allio (aka Obi-wan Kenobi) [2017/01/14]
See: https://forums.adobe.com/thread/2263331
app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.FAST_ENTIRE_SCRIPT, "Anchor Text Selection! …");
function main()
try {
var myOStyle = app.activeDocument.objectStyles.item("mySel");
myOStyle.name;
} catch (e) {
You show us an anchored item, your question is not that clear: what exactly do you want?
Before: I select text. After: New textframe and into the selected text
Select the text.
Cut it from the text frame.
Deselect the text frame.
Choose Paste.
Adjust the new text frame to see all the text.
Click where you want the text to be.
Choose Paste.
HOWEVER if you don't mind losing the text as text, select the text.
Choose Create Outlines from the Type menu
The text will be converted to an object in the text flow.
Just use The Force!
function main()
try {
myOStyle.name;
} catch (e) {
var myOStyle = app.activeDocument.objectStyles.add({name: "mySel", enableFill: false, enableStroke: false});
var mySel = app.selection[0],
myLeading = mySel.leading,
myFrame = mySel.insertionPoints[-1].textFrames.add();
mySel.characters.itemByRange(0, mySel.characters.length-2).move (LocationOptions.after, myFrame.insertionPoints[0]);
myFrame.textFramePreferences.autoSizingType = AutoSizingTypeEnum.HEIGHT_AND_WIDTH;
myFrame.textFramePreferences.useNoLineBreaksForAutoSizing = true;
myFrame.insertionPoints[0].leading = myLeading;
myFrame.applyObjectStyle(myOStyle);
// _____ (^/) _____ \\
… and join The Rebellion!
I second Frans: what's the final goal of all this? What do you expect to gain? Isn't it just another incarnation of the famous 'xy problem"?
Thank you so much by Obi-wan
