LR changes jpg WB when changing dimensions on export
Participant ,
Jan 14, 2017 Jan 14, 2017
LR 5.7
When I export from LR without changing the dimensions then all is well.
But if I export and make the dimensions smaller, then please look at my jpg
Does this have to do with "export with previous" perhaps?
When I make the size reduction in PS then the problem doesn't occur.reduced in ps.jpg
Thanks for any help.
392
Explorer , Jan 15, 2017 Jan 15, 2017
sRGB
I think I've found the culprit and it's pretty dangerous if you don't know about it, which I didn't.
Export with previous !
It not only remembers folder location,sharpening and dimensions but it remembers presets too.
So one day you export a photo with a preset and sometime later you use "export with previous" it will apply the same preset.
I think that's the way it works and comments would be more than welcome.
Michael
The large photo (you posted) shows it as "uncalibrated"
Are you exporting to JPG using sRGB?
Check both the export dialogs  (Presets?) are they both using sRGB.
Participant ,
Thanks for the very quick and quite likely answer to the problem.
I have never changed this.
Where do I check and if necessary, change the setting?
Thanks.
This doesn't happen if I export to the same folder and don't change the dimensions.
Michael
Check in the Export dialog / File Settings / Color Space:-
It might not be the correct answer, but try.
sRGB
Michael
The "way it works" I think is also rather cryptic, and 'help' is rather minimal-
Quote from the Lr Help Reference file-
Export photos using the previous settings
You can export photos using the same settings from the most recent export session that was set manually, including  modified presets. Otherwise, the Export With Previous command does not work with export presets.
"Export with previous" works exactly they way I expect it to.
It is exactly like going to the Export dialog, changing nothing, and pressing the ok/go/export button.
Since I don't usually remember what the previous settings were, I never use "export with previous".
Jan 16, 2017 Jan 16, 2017
Now that I understand it I see that it works exactly as it's supposed to.
I guess if someone has multiple photos from a shoot and applied the same preset to each of them, then it would make sense to tag and export them in bulk.
It would be nice if one could see what preset would be applied.
I will be very careful of using "export with previous" in future.
Michael
