I just installed the drivers for Canon MX922 printer on MAC with OS 10.11.6 (El Capitan). I can print/scan from the printer without issues. When I open up Lightroom CC however, the Canon printer/paper ICC's are not there. I went into "other" and looked at all of the ICC profiles in lightroom but NO Canon profiles are there. Other paper profiles are there but no Canon profiles.
Does anybody know how to fix this?
Thanks in advance
This happen due to improper installation. Try to delete the downloaded and accompanying profile and re-download and install the profile again. Make sure you must delete that profile which you was using before. I hope this troubleshooting tip would helpful to you if it doesn't work than don't worry try another web services and alternative troubleshooting tips from Canon PIXMA MX922 Manual.
Although I don't use a Mac anymore I thnk, IIRC, you set paper profiles in the printers preferences. But I might be mistaken.
Paper type is set in the printer preferences. However, the paper profile is chosen in Lightroom. I'm wondering if the OP installed paper profiles. I'm also wondering if that printer supports paper profiles. I didn't see any listed on the Canon website. However, Red River seems to have some paper profiles that will work with it.
Thanks. This seems to be the fix.
Thanks sharond4634384. This seems to have fixed it.
