Hello,
Last night I tried to do an update for CS6 and the update stalled at 81% and now the application won't open. I am on a MacBook Pro (2010) and running El Capitain. I have tried to restart the update but I can't seem to figure that out. Suggestions? I'm not in a panic because the project I was working on has been sent to the printer. However... I would like the program to start working.
Please follow the steps in "Installation failed" error U44M1P7 with Adobe Creative Cloud or Adobe Creative Suite 6 updates to resolve the issue.
Regards
Sanyam Talwar
At some point in the past (I don't know the exact date) Adobe "merged" the original update manager into the Cloud update manager, which means you are no longer using your original update manager
I have read some messages that the latest (Cloud) updater sometimes doesn't work with old programs... Try installing your updates manually
Updates start here and select product, read to see if you need to install updates in number order, or if the updates are cumulative for the individual product http://www.adobe.com/downloads/updates/
Also, For Mac El Capitan or the newer Sierra operating system read below
Owners of old programs simply have problems with Mac El Capitan/Sierra... none of which is Adobe's fault... Adobe did not change your old program to make it stop working... Apple changed their operating system and THAT is why your old programs won't work, not because of anything Adobe did... Also... every time Apple issues an update, there is the risk that an old program that HAS been working will STOP working... bottom line, old programs require a matching old operating system
Thank you for the response. At this point I just want the program to load.
The only reliable way would be for you to either revert to an earlier OS or upgrade to InDesign CC2015/17.
Really? That just seems unfair. Apple and Adobe should play nicely together. I tried the manual update and got this error code: Installation failed. Error Code: U44M2P7
Does that mean I am toast with this program?
U44.. update error http://forums.adobe.com/thread/1289956 may help
Go back and re-read what I wrote in reply 1
Adobe is not going to go back and update a 4+ year old program when Apple makes changes
As I said, and as Derek said in reply 3, an old program requires a matching old operating system
This is Apple's fault for not maintaining backward compatibility
Regards
Sanyam Talwar
