Error Code 1151
Jan 15, 2017 Jan 15, 2017
I built my website with Flash in 2010 (Action Script 2.0) and am trying to add material, now using Animate CC 2017 (which requires it to convert to AS 3.0).
When I open the old .fla file and then run thru Control/Test Movie it comes up with the following error code message:
"1151 A conflict exists with the definition MyHoriTween in namespace internal".
In the Actions pane, the offending code reads:
____________________________________________
import mx.transitions.Tween;
import mx.transitions.easing.*;
var myHoriTween:Tween = new Tween (Logo_ON_mc,"_x",Strong.easeOut,-450,-74,2,true)
___________________________________________________________
And there are 3 other 1151 type errors all relating to Tweens.
Can anyone help?
1.3K
Community Expert , Jan 16, 2017 Jan 16, 2017
that should be:
import fl.transitions.Tween;
import fl.transitions.easing.*;
(p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
you shouldn't re-declare the same variable:
should only appear once on any one timeline/class.  it can be reused but that's not necessarily wise. using different names is more prudent:
var tween1:Tween = whatever;
var tween2:Tween = whatever else;
etc.
Thanks kglad.
I think I fixed that (at least the errors went away--though it still cycles through without stopping) but now I am getting an error code regarding the Sound layer:
1046 Type was not found or was not a compile-time constant: Void
And this was the code line it was referencing
var game_sound:Sound = new Sound();
game_sound.onLoad = function(success:Boolean):Void {
if (success) {
trace("Sound Loaded");
game_sound.start();
game_sound.loadSound("pagechangeSFX2.mp3", false);
Any thoughts?
Scott
that should be void.  actionscript 3 is case-sensitive.
More error codes:
1120 Access of undefined property percent
Here is the code block it is referencing:
percent = Math.floor(getBytesLoaded()/getBytesTotal()*100);
loadingPercent.text = percent + " %";
Also,
1180 Call to an undefined method getbytestloaded
Code:
Also,
1120 Access of undefined property progressBar_mc
Code:
//create clips to hold your content
this.createEmptyMovieClip("progressBar_mc", 0);
progressBar_mc.createEmptyMovieClip("bar_mc", 1);
progressBar_mc.createEmptyMovieClip("stroke_mc", 2);
//use drawing methods to create a progress bar
with (progressBar_mc.stroke_mc) {
lineStyle(0, 0x000000);
moveTo(0, 0);
lineTo(100, 0);
lineTo(100, 10);
lineTo(0, 10);
lineTo(0, 0);
with (progressBar_mc.bar_mc) {
beginFill(0xFF0000, 100);
moveTo(0, 0);
lineTo(100, 0);
lineTo(100, 10);
lineTo(0, 10);
lineTo(0, 0);
endFill();
_xscale = 0;
progressBar_mc._x = 2;
progressBar_mc._y = 1143;
// load progress
var mclListener:Object = new Object();
mclListener.onLoadStart = function(target_mc:MovieClip) {
progressBar_mc.bar_mc._xscale = 0;
mclListener.onLoadProgress = function(target_mc:MovieClip, bytesLoaded:Number, bytesTotal:Number) {
progressBar_mc.bar_mc._xscale = Math.round(bytesLoaded/bytesTotal*100);
mclListener.onLoadComplete = function(target_mc:MovieClip) {
progressBar_mc.removeMovieClip();
mclListener.onLoadInit = function(target_mc:MovieClip) {
target_mc._height = 500;
target_mc._width = 700;
to solve that percent error, use:
var percent:Number = Math.floor(this.loaderInfo.bytesLoaded/this.loaderInfo.bytesTotal*100);
for your progressBar_mc error, you need to define progressBar_mc either on stage or in code.
Next errors:
Error Message:
1172: Definition mx.transitions:Tween could not be found
1172: Definition mx.transitions.easing could not be found
Code:
var myHoriTween:Tween = new Tween (Logo_OFF_mc,"_x",Strong.easeOut,-450,-83,2,true);
that should be:
Thanks, kglad!
Here is the next issue:
Error Message:
1067: Implicit coercion of a value of type int to an unrelated type string
Code:
if (percent ==100){
gotoAndPlay("animation",1);
}else{
gotoAndPlay(1);
Also, kglad I would be interested in paying you to clean up all the code on this website if you are interested.
Thanks, kglad!
Here is my next issue:
Error Message:
Code:
if (percent ==100){
}else{
gotoAndPlay(1);
