I am having an oversaturation problem with my raw pictures taken with my Canon 60d. They look way oversaturated in photoshop cc. When I import them in Jpeg they look perfect. Pictures imported from my other camera Canon 6d both jpeg and raw are fine. I have been using my Canon 60d with Photoshop for years and I never had this problem. I wonder if anyone could help me with this. I do not want to change any settings in photoshop because it does work with my 6d. This happened right after one of the latest updates.
I have Photoshop ver. 2017.0.1
20161130.r.29x64
Windows 10
If rolling back doesn't work, screen shots of the problematic images would be very helpful.
You might also go through all the Camera Raw setting to make sure they are all truly set to the defaults. In particular, the basic, tone curve, and camera calibration tabs.
Are you importing with Bridge?
No. I double click on the files and they open in Photoshop.
I just tried with Bridge. Still having the same problem.
When you double click on a RAW file or use Bridge to open it that image file most first go through Adobe Camera RAW and you make no mention of this. So you are not opening RAW files.
It is true that I did not mention it but I thought it was obvious that if
you open a raw file it opens in camera raw. Yes I am opening raw files.
In Bridge, right click on one of the Raw files > develop settings > clear settings. Any change?
I did clear settings in bridge but it still did not solve the problem.
Well it wasn't obvious because ACR is where you do all the adjustment to a RAW file before it loads into PS.
And what adjustments are you applying in ACR?
On Tue, Jan 17, 2017 at 5:51 AM Just Shoot Me <forums_noreply@adobe.com>
are you resetting ACR back to it's defaults after opening from within Photoshop?
Yes.
difficult one as your other camera is working. The two cameras do have different ACR requirements so maybe there is a bug in the latest ACR that just effects the 60D. I would suggest downgrading camera raw.
Camera Raw installer for Adobe Photoshop CC and CS6
The latest ACR is 9.8.0.692 so maybe try ACR 9.5.1 or even ACR 9.1.1. Both support your two cameras , but if the problem persists you can still easily reinstall ACR 9.8.0.692
On Tue, Jan 17, 2017 at 9:26 AM Terri Stevens <forums_noreply@adobe.com>
Hi Donna the software on this forum doesn't work well with cell phones. To be sure of having your messages seen it's best to use a computer.
Ok. Thank you.
A few of your replies only contain a brief email transcript. Replying via email doesn't always work, so please try responding again directly in the forums. Thanks!
Go to "Camera Calibration" which is located in the "Camera Raw" panel within Photoshop.
Then change the Adobe Standard setting which is located under "Camera Profile" in there choose Camera Standard.
