Hello everybody,
I'm following this official tutorial VIDEO COPILOT | After Effects Tutorials, Plug-ins and Stock Footage for Post Production Professional... cause i need to learn how to build new materials for 3D element.
I wanna reproduce the element that the tutor builds at min. 5:27, the one showed in the preview Scene Material window.
Everything's going good but i noticed that in my preview the materials is not the same as you can see in this pic.
When the guy change the Intensity of reflection value, the preview of the material changes this way
but mine preview doesn't change. Probably i worked on the wrong parameters but i can't understand why it doesn't change.... any suggestion?
thnx,
Mushanga75
Without any info about your system and what textures you use nobody can tell you much. Aside from that, simply ask on the VC forum for specifics.
Mylenium
Oh sorry..ur right as usual!
Probably i have to improve my use of the Forum and not only the use of AE... 🙂
btw thnx a lot Mylenium
Mushanga75
Hi Mushanga,
Did you ever solve this issue? If so, how did you do it? Let us know so that others can benefit. If not, do return and give us more info so we can help you.
Kevin
Not yet...
i tried to build the material, but i still have to understand how to...
thnx for asking Kevin
Hi Mushanga,
I would head over to the Video Copilot forum for assistance with Element 3D. Can you try that?
Kevin
