I just had to rebuild windows from scratch. Formated the drive and everything. After putting all the important
stuff back on such as net framework, directx, C destributables, quicktime, flash and Java 7. I installed Premiere Elements 13
and it fails to launch. Remember this is a fresh windows,
The antivirus (BitDefender) is now fully updated, I found and old thread on this topic and worked through it but nothing
resolved it.
So I am left with it crashing during launch every single time. Could someone suggest a way to fix this please?
Chris
Might help to know which Windows version you've installed -- as well as what processor you have, how much RAM and how much free space is on your hard drive. It might also be valuable to know what graphics card you have.
Also, is your computer a brand name (HP, Dell, Compaq)? If so, you should go to that manufacturer's support site and install its hardware drivers.
You should also install Quicktime 7, per the program's requirements and you should go to your GPU manufacturer's site for the latest d
...Copy link to clipboard
You should also install Quicktime 7, per the program's requirements and you should go to your GPU manufacturer's site for the latest driver for your graphics card.
Hi Steve,
[SOLVED]
Thanks for that. Most of those were installed, but the video driver was the previous version than the latest.
Putting the latest Nvidia 760 GTX on it (on Windows 7 Pro system) solved the problem.
Thank you Steve.
