I have created window for a process and it was working fine. Recently getting error in one machine (Mac 10.9.5). I don't know the reason for the error. Script is not running. Dialog is not created. But its working in other machine.
If i click the "OK" button, then i get the below error.
Code:
var myDlg = new Window('dialog', 'Dialog Title');
roundTypePanel = myDlg.add('panel', undefined, "Round ");
roundTypePanel.orientation = 'row';
var rad1 = roundTypePanel.add('radiobutton', [156,75,325,105], "Round 1");
var rad2 = roundTypePanel.add('radiobutton', [156,75,325,105], "Round 2");
rad1.value = true;
roundType = 1;
myDlg.show();
Can anyone help me??
- Sudha K
Hi Sudha,
Your code is working fine.
var myOkButton = myDlg.add ("button", undefined, "OK");
var myCancelButton = myDlg.add ("button", undefined, "Cancel");
rad1.value ==true;
roundType = 1;
myDlg.show();
Prabu G
I confirm it works at my place. Maybe you should trash your preferences.
Thank you... I will check and let you know...
Why should we remove the preferences?? For me also its working in another system. I don't know the reason for this...
Whats the issue in this??
Well your code works for most of the users who tried it. You have only one desk where it doesn't and it's on your machine.
So I am guessing maybe something is wrong with your own configuration. So trashing preferences is generally a good way to start indesign from scratch and get back to the standard configuration.
Have a try. At least it will discard this reason. Do you know the first rule in computer support ? …restart to see if problem is gone.
Sorry for the late reply...
I cleared the InDesign preference and then run the script, its working. If I restart the computer after cleared the InDesign preference, its throwing the same error. I don't know the reason for this issue and how to run the script.
Don't you have any startup scripts which could corrupt the app ? Worst case scenario a new install from scratch.
Thank you for your reply... I will check and come back...
How to check startup scripts?? Any scripts placed inside the folder "startup scripts"??
yes that's the idea. Obvioulsy something is messing your app. It could be a startup script or a plugin that once called makes things dirty unless you clean preferences till next call.
There is no scripts inside the "startup scripts" folder.
Any third parties plug-in ?
Any third party plug-in for an InDesign application?
There is no third party plug-in and startup scripts.
Well, no more hints to give.
Hm. Would shielding the code be of use?
Like using another targetengine—not main—and put it into an anonymous function?
#targetengine sudha
var runThis = function()
rad1.value = true;
roundType = 1;
myDlg.show();
runThis();
FWIW: Sudha's code is running well with my tests on InDesign CC 2017 on Mac OSX 10.10.5.
With or without using a different targetengine:
Uwe
