Dreamweaver 2017, working on a php file. If I select a line and command 'x'/cut I get a pop-up dialog listing; __CLASS__, __COMPILER_HALT_OFFSET__, and so on. It's not of use to me and very irritating, is there a way to I prevent the pop-up?
Can you post a screenshot for us? Meanwhile, I will check with the product team.
You can also report your issue to the team using Adobe Dreamweaver CC: Feature Ideas
Preran
Thanks, here's a screenshot
Thank you. I have forwarded this post.
Meanwhile, I am hoping that one of the experts here has a better idea about this one.
Any luck on this, anyone? this pop-up is driving me nuts!
I haven't heard back from the people I wrote to. I suggest checking with the team using Adobe Dreamweaver CC: Feature Ideas
Preran
In Preferences > Code Hints, did you disable description tooltips?
Both are unticked in my preferences, I would assume that makes them disabled. I'll tick tools tips and see if that removes them.
Thanks.
Sadly code hints and tooltips checked or unchecked the pop-up still appears. Feels more like a bug than an intended feature.
Just updated to 2017.5, this pop-up is still driving me crazy. 'code hints > enable description tool tips' is unticked, is there any way to disable it before I through my machine out of the window?
