I am unable to secure a pdf from being able to copy and paste. As in, you can make the selection in the security settings and save the document, and the settings are just totally ignored. This is in an enterprise environment using Adobe Acrobat Pro 11 and affects machines running Windows 7 and Windows 10. The kicker is, it works in our virtual environment running Windows 7. I have taken several documents that function as expected in the virtual environment and tried them on physical machines just to rule out an issue with the document itself. We are not running any type of group policy for Adobe Acrobat Pro 11. I verified this in both physical and virtual environments. I know I have missed something, somewhere. I have a feeling the problem lies with some sort of group policy setting but haven't a clue which one. Any suggestions?
badfishtoo wrote:
I am unable to secure a pdf from being able to copy and paste. As in, you can make the selection in the security settings and save the document, and the settings are just totally ignored. ...
How did you check this?
Took the test document and opened it in the virtual environment. Attempted to copy text, but the option to copy is grayed out. Which is the expected behavior. Took the same document and opened on a physical machine, right click, copy and it allows copying the text and then pasting in to notepad, word, outlook, etc.
Do you use Acrobat Reader or Adobe Acrobat on the physical machine?
What can you see under security in the document properties?
Security method > Password Security
Can be opened by: Acrobat 7.0 and later
Printing: Allowed
Changing the document: Not allowed
Document Assembly: Not allowed
Content Copying: Not Allowed
Content Copying for Accessibility: Allowed
Page Extraction: Not Allowed
Commenting: Allowed
Filling of form fields: Allowed
Signing: Allowed
Creation of Template Pages: Not Allowed
Then Acrobat can't copy the text.
Which is where the problem lies. I can indeed copy and paste text. On physical machines. I can open that same document in our virtual environment and it works as it should.
Can you share one document?
