on line help doesn nt work.
looking for the help there is this message
Impossibile trovare l'indirizzo DNS del server community.stage.corp.adobe.com.
And what exactly are you looking for .. help with ?!?
I was look ing about file import. But it is the all help which is not
reacheable
Il 15 Gen 2017 17:49, "F. McLion" <forums_noreply@adobe.com> ha scritto:
help created by F. McLion <https://forums.adobe.com/people/F.+McLion> in *Photoshop
Lightroom* - View the full discussion
<https://forums.adobe.com/message/9264102#9264102>
Correct!
Thank you very much
This was fixed n LR 6.1. Please update to the latest version 6.8, using Help> Updates. Once installed Help> Lightroom Help (F1 key) should take you to this link for your language setting: Informazioni e supporto su Adobe Photoshop Lightroom
I run the update, but after the installation Lightroom doesn't start anylonger.
A window pos up stating:
"Impossible to start the program because
api-ms-win-crt-runtime-[1-1-0.ddl] is not present ion the PC.
To solve the problem try to reinstall the program"
I can try to reinstall, but I will miss the update!
angelo bosoni
You can download the 6.0 installer as well as the 6.8 update directly from here: Install Photoshop Lightroom
thanks.
but after the download how do I install the software?
The system prompt for "open" or "save"
Do a save. Then: Double-click on the downloaded file.
OR
Click on Open
NO WAY.
system asks for select a program to open the file listing "acrobat" and other raeding file.
Please see this article to install the missing DLL:
Error :api-ms-win-crt-runtime-l1-1-0.dll is missing
Retry installing the 6.8 update.
correct. THANKS
