If I right click on a text layer, in Lay panel can I choose the following converting options:
Convert to Smart Object
Rasterize Type
Rasterize Type Style
Convert to Shape
And why can't use all tools of some one of them ?
If I right click on a layer (graphic), in Lay panel can I choose the following converting options:
"Convert to Smart Object" but what i a "Smart Object" ?
but what is the difference between allt these options?
Rasterize Type
Changes a Type Layer to a pixel Layer
Changes the Layer with applied Layer Styles to a pixel Layer
Convert to Shape
Changes the Type Layer to a Shape Layer (a Solid Colour Layer with a Vector Mask)
Convert to Paragraph Text
Changes Point Text to Paragraph Text – these are two possibilities to set up Type Layers in Photoshop, in the one case one defines a starting point from which the text flows in the other a rectangle that gets filled with the text
You may want to start with some beginners level tutorials if all those terms mean nothing to you yet.
The advantages of Smart Objects are numerous:
• external files can be referenced and represented in layered documents
• multiple instances of a SO in a containing document that update simultaneously on saving an edited SO (please note that for a SO to maintain a connection to the external file one needs to use File > Place Linked instead of File > Place Embedded )
• the possibility of placing vector content as Vector Smart Objects (though this will output as pixels)
• non-destructive application of Filters
• non-destructive application of transformation, warp, puppet warp (not all of these are available for Vector SO, but by converting such a one to a regular SO they become applicable)
• combination of elements of different color spaces and bit depths
• the ability to Replace Contents of SO (for example when faking as-of-yet non-existent products by mapping packaging design elements onto images of a blank container and the design is likely to change)
• Stack Modes for certain combinations of photographic images
Rasterize Type
Convert to Shape
