When I shoot a hockey game I use 2 cameras.
If the action is at the far end I use one camera and lens and as it gets closer I switch to another camera with a shorter lens
When I get home I load the 2 memory cards into one folder and import into Lightroom
When I'm done editing I export them to a folder on my desktop
Is there a way I can have these sorted by time taken as the order is important
Just before I export I now go into the filmstrip and drag the opening faceoff to the first of the filmstrip and the scoreboard showing the final score is the last photo
Then when I open my file on my desktop the scoreboard photo is not the last photo to be viewed in the folder
Ex: I could be shooting a rush from the far end coming towards me using one setup
Then I switch to my other camera and lens and shoot the action in front of me
Then another rush from the far end using the long lens and other camera etc etc
When I get the photos uploaded into LR the order is the 6 photos from the first rush, followed by 10 pics from the 2nd rush and then the photos of when the action is directly in front of me
Once they hit the folder using Windows 10 I can't arrange them, preference would be having LR do my sort.
Thxs
Use the menu command View->Sort->Capture Time
You might also need to synchronize the time on the two cameras first, or you can do this afterwards
I tried as you suggested and it didn't work.
I understand that you can use "sort by date" but are you thinking that it will sort by time using the minutes as the sort criteria?
Thxs
Please be very specific. Which of the two things I suggested did you try? Exactly what happened?
Sort by Capture Time, not sort by Date. It means exactly what it says, it sorts by Capture Time.
View >sort>capture in LR
It has the opening faceoff (which is the very first photo taken that day) and the scoreboard showing the score is in the middle of the file of photos and it was the last photo taken that day.
I want to have the the faceoff at the first and the scoreboard at the last
Then the time in your two cameras is not synchronized. I gave a link that explains how to fix this after the fact.
I just synched my two cameras
They were out by over an hour
Considering that the hockey and ringette games (kids) are less than an hour thats quite a difference
I'll be shooting another hockey game tomorrow night using both cameras
I'll definitely be trying the sort by time
Thxs
