Herewith an email sent to muse-support@adobe.com and they referred to this forum. There is however so many "solutions" and I have scanned a myriad so-called solutions an none of them is working, for some perhaps in minor situations but not this one - I have to make a decision whether to buy or not!!
I have tried about all options mentioned in the forums to no avail, restart, re-login, uninstall, re-install, Typekit profile, even had a look in the registry if I can find something that causes the "Bad IMS status SHARED_UNKNOWN_ERROR 67" error as in the attached logs.
I want to buy Muse, but I cannot at this stage and has only 6 days trial left. I have taken over another person's web development and what I have seen he can do perfect Muse development from a Windows 8.1 laptop. I have installed Muse Trail on my desktop (Win7 Home) - see configuration below - but I cannot access Typekit from within the MUSE fonts dialog - in fact I see nothing - just a message about cannot preview the fonts. One of the websites (call it website X) taken uses a Typekit font, and when exporting this website from my desktop PC (HTML or FTP) it bombs out respectively stopping at 26% and error 500 which according the forums I understand is a Typekit "connectivity" issue???
I then installed Muse Trial on my Win10 laptop (corei3 which is too slow) and everything was working perfect. I could see the Typekit fonts in die Muse font dialog using the Add/Delete Web Fonts menu option and then I deleted the Typekit Lato font which was in use in the website X and replaced it with the Edge Web Fonts font (Lato light & regular). I exported and FTP'ed the website X with no issues - again from the Win10 laptop. I then uninstalled Muse Trial from the Win10 laptop and went back to Desktop PC, opened the modified website X with Muse (now with apparent no Typekit fonts) again, and the issue persist with the export to HTML or FTP. I was under the impression the TypeKit font should have been removed when using the Win10 laptop, however I still cannot see the Typekit fonts in the Muse font dialog.
Below is a couple of screen-grabs going through the processes described in the forums. I dearly hope you can help me. This is my business and I need to aquire Muse and continue working on this website X. Perhaps it is a firewall configuration, but then I need to have specifics how to set it up.
In summary, everything works perfectly in the Win8.1 and Win10 OS, but not on Win7 and everythings works perfect with the Edge Web Fonts.
Any help would be appreciated, just do not refer to other forum post links, the "solutions" does not work - rather give me a new solution that will work. If I can just remove the invisble Typekit font then I'd be happy. It seems to me there is a lot of issues using Typekit. And do not refer me to the Typekit website - I have been there multiple times trying.
The MuseLog.txt file of the steps taken is at the end of this message. The error concerning me is:
[00:08:10.171] 08:27:15.186 | 00:00:00.125 | 319 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.171] 08:27:15.186 | 00:00:00.000 | 320 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
Below is some images of the steps taken when trying to sort out the issue and export the website X which by now "had a TypeKit font" removed using the Win10 laptop with a perfect working Muse and TypeKit.
I HAVE 6 DAYS LEFT AND NEED AN SOLUTION BEFORE I CAN BUY MUSE
Desktop PC OS
Start with export to HTML
Bombs out at 26%
No Typekit fonts in the Muse... ????
CC manager logs of on its own, constant re-sync of a font - strange behaviors - reinstalled, logged off, restarted PC etc. etc. etc.
Logged out from Muse, restarted, open with this message - understandable
Re-login muse, CC manager pops up also for a login... ???? strange
Again syncing of Typekit font - eventually removed it from Typekit site
I use MWB - had no issue on Win10 laptop
MuseLog.txt
Logging in build 2017.0.1.11 started at: Thu Jan 19 08:19:04 2017
[00:00:00.000] path = C:\Program Files\Adobe\Adobe Muse CC 2017\
[00:00:00.000] 10.0.0 build info=10.0.0.47,7.0
[00:00:00.000] start Muse with AMT license validation. AMT mode = release
[00:00:00.000] Loading AMT
[00:00:00.000] Application locale - en_US
[00:00:00.000] AMT features
[00:00:00.000] AMT_REDUCED_TRIAL_NAGS_NONE 1 0
[00:00:00.000] AMT_SUBSCRIPTION 6 0
[00:00:00.000] Muse 2 0
[00:00:00.000] Muse_Base 1 0
[00:00:00.000] Muse_Base 2 0
[00:00:00.000] Call AMTObtainProductLicense with params AMTInteractionMode_beforeProductUI and AMTLibraryLoadStrategy_atValidate
[00:00:00.016] AMTObtainProductLicense return 0
[00:00:00.016] AMTObtainProductLicense return locale - en_US
[00:00:00.016] AMTProductInfo
[00:00:00.016] status = 1
[00:00:00.016] GUID = V7{}Muse-15-Win-GM
[00:00:00.016] name = Adobe Muse CC
[00:00:00.016] remainingDurationInSeconds =
[00:00:00.016] AMTEnigmaRecord
[00:00:00.016] product id = 576
[00:00:00.016] serial = 907187007678939563878457
[00:00:00.016] display serial = 90718700767893956387
[00:00:00.016] Product version = 2.0
[00:00:00.016] Platform = 1
[00:00:00.016] Language = en_US
[00:00:00.016] Education product = 0
[00:00:00.016] Prerelease product = 0
[00:00:00.016] Point product = 1
[00:00:00.016] Trial = 1
[00:00:00.016] Volume licensed = 0
[00:00:00.016] Subscription License = 0
[00:00:00.016] AMTExpirationData
[00:00:00.016] Expiration type = 0
[00:00:00.016] Has expired = 0
[00:00:00.016] AMT menu items
[00:00:00.016] menu item = Manage My Account...
[00:00:00.016] menu item = Sign Out (spcornelissen@gmail.com)
[00:00:00.016] menu item = Updates...
[00:00:00.016] Call AMTPreValidateProductLicense
[00:00:00.032] Detected license type - TRIAL
[00:00:01.139] AMTPreValidateProductLicense background status = 2
[00:00:01.217] AMTValidateProductLicense return 1
[00:00:01.935] Load IMSLib from C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P7\x64\IMSLib.dll
[00:00:01.935] IMS library loaded
[00:00:02.138] amtReady=true, elapsed=203
[00:00:02.138] AMTRetrieveAdobeID. AdobeID = spcornelissen@gmail.com
[00:00:02.138] IMS: IMS_createRefEx inIMSEndpoint = ims-na1.adobelogin.com
[00:00:02.138] Call IMS_fetchAccessToken with params
[00:00:02.138] Client id = BCMuse1
[00:00:02.138] Client secret = 32...23de
[00:00:02.138] User guid = 13...E9@AdobeID
[00:00:02.138] Service guid =
[00:00:02.138] Scope = openid,AdobeID,sao.business_catalyst,creative_cloud
[00:00:02.138] IMS_fetchAccessToken status = 67
[00:00:02.138] Client id = MuseTypekit2
[00:00:02.138] Client secret = 23...c9fd
[00:00:02.138] Scope = openid,AdobeID,sao.typekit,creative_cloud
[00:00:02.153] Call IMS_fetchAccessToken with params
[00:00:02.153] Client id = ProjectHello1
[00:00:02.153] Client secret = 2e...8eaa
[00:00:02.153] User guid = 13...E9@AdobeID
[00:00:02.153] Service guid =
[00:00:02.153] Scope = openid,AdobeID,creative_cloud
[00:00:02.153] IMS_fetchAccessToken status = 67
[00:00:02.153] AMTPreValidateProductLicense background status = 3
[00:00:02.153] AMTProductInfo
[00:00:02.153] status = 1
[00:00:02.153] GUID = V7{}Muse-15-Win-GM
[00:00:02.153] name = Adobe Muse CC
[00:00:02.153] remainingDurationInSeconds =
[00:00:02.153] AMTEnigmaRecord
[00:00:02.153] product id = 576
[00:00:02.153] serial = 907187007678939563878457
[00:00:02.153] display serial = 90718700767893956387
[00:00:02.153] Product version = 2.0
[00:00:02.153] Platform = 1
[00:00:02.153] Language = en_US
[00:00:02.153] Education product = 0
[00:00:02.153] Prerelease product = 0
[00:00:02.153] Point product = 1
[00:00:02.153] Trial = 1
[00:00:02.153] Volume licensed = 0
[00:00:02.153] Subscription License = 0
[00:00:02.153] AMTExpirationData
[00:00:02.153] Expiration type = 0
[00:00:02.153] Has expired = 0
[00:00:02.153] AMT menu items
[00:00:02.153] menu item = Manage My Account...
[00:00:02.153] menu item = Sign Out (spcornelissen@gmail.com)
[00:00:02.153] menu item = Updates...
[00:00:04.010] 08:19:09.011 | 00:00:00.000 | 1 | [MuseIMSManager] | Typekit Level (Numeric): -2
[00:00:04.119] 08:19:09.128 | 00:00:00.117 | 2 | [Web Font API] | Making GET to https://api.typekit.com/muse_v1/families/qnhg
[00:00:04.665] 08:19:09.667 | 00:00:00.539 | 3 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:00:04.680] 08:19:09.695 | 00:00:00.028 | 4 | [MuseIMSManager] | Typekit Level: UNKNOWN
[00:00:04.680] 08:19:09.697 | 00:00:00.002 | 5 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:00:04.696] 08:19:09.698 | 00:00:00.001 | 6 | [Typekit] | No font listing in disk cache
[00:00:04.821] AMT detects license type change.
[00:00:06.022] 08:19:11.025 | 00:00:01.327 | 7 | [Web Font API] | onHTTPResponseStatus. Status=200 response for https://api.typekit.com/muse_v1/families/qnhg
[00:00:06.022] 08:19:11.025 | 00:00:00.000 | 8 | [Web Font API] | onHTTPStatus. Status=200 response for https://api.typekit.com/muse_v1/families/qnhg
[00:00:06.022] 08:19:11.025 | 00:00:00.000 | 9 | [Web Font API] | onComplete. Got some data and 200 response for https://api.typekit.com/muse_v1/families/qnhg
[00:00:06.022] 08:19:11.025 | 00:00:00.000 | 10 | [Web Font API] | Elapsed ms: 1897
[00:00:06.022] 08:19:11.028 | 00:00:00.003 | 11 | [Web Font API] | Making GET to https://api.typekit.com/muse_v1/families/nqdy
[00:00:06.287] 08:19:11.303 | 00:00:00.275 | 12 | [Web Font API] | onHTTPResponseStatus. Status=200 response for https://api.typekit.com/muse_v1/families/nqdy
[00:00:06.287] 08:19:11.303 | 00:00:00.000 | 13 | [Web Font API] | onHTTPStatus. Status=200 response for https://api.typekit.com/muse_v1/families/nqdy
[00:00:06.287] 08:19:11.303 | 00:00:00.000 | 14 | [Web Font API] | onComplete. Got some data and 200 response for https://api.typekit.com/muse_v1/families/nqdy
[00:00:06.287] 08:19:11.303 | 00:00:00.000 | 15 | [Web Font API] | Elapsed ms: 275
[00:00:06.287] 08:19:11.304 | 00:00:00.001 | 16 | [Web Font API] | Making GET to https://api.typekit.com/muse_v1/families/dwgd
[00:00:06.740] 08:19:11.746 | 00:00:00.442 | 17 | [Web Font API] | onHTTPResponseStatus. Status=200 response for https://api.typekit.com/muse_v1/families/dwgd
[00:00:06.740] 08:19:11.746 | 00:00:00.000 | 18 | [Web Font API] | onHTTPStatus. Status=200 response for https://api.typekit.com/muse_v1/families/dwgd
[00:00:06.740] 08:19:11.746 | 00:00:00.000 | 19 | [Web Font API] | onComplete. Got some data and 200 response for https://api.typekit.com/muse_v1/families/dwgd
[00:00:06.740] 08:19:11.746 | 00:00:00.000 | 20 | [Web Font API] | Elapsed ms: 442
[00:00:06.740] 08:19:11.747 | 00:00:00.001 | 21 | [Web Font API] | Making GET to https://api.typekit.com/muse_v1/families/jxfv
[00:00:07.130] 08:19:12.131 | 00:00:00.384 | 22 | [Web Font API] | onHTTPResponseStatus. Status=200 response for https://api.typekit.com/muse_v1/families/jxfv
[00:00:07.130] 08:19:12.131 | 00:00:00.000 | 23 | [Web Font API] | onHTTPStatus. Status=200 response for https://api.typekit.com/muse_v1/families/jxfv
[00:00:07.130] 08:19:12.131 | 00:00:00.000 | 24 | [Web Font API] | onComplete. Got some data and 200 response for https://api.typekit.com/muse_v1/families/jxfv
[00:00:07.130] 08:19:12.131 | 00:00:00.000 | 25 | [Web Font API] | Elapsed ms: 384
[00:01:02.151] TokenMonitorIdleProc. elapsed=1.0 userGUID=13...E9@AdobeID
[00:01:02.151] ProjectHello1 : IMSStatus=67 signInStatus=3
[00:01:02.151] MuseTypekit2 : IMSStatus=67 signInStatus=3
[00:01:02.151] BCMuse1 : IMSStatus=67 signInStatus=3
[00:01:39.794] 08:20:44.800 | 00:01:32.669 | 26 | [alwaysOn] | Trying to open file 'W:\WebSiteDev\thornbay\Thornbay\thornbay.muse with size:40894464 mod Date:Thu Jan 19 07:42:59 GMT+0200 2017
[00:01:41.697] 08:20:46.705 | 00:00:01.905 | 27 | [alwaysOn] | Opening file 'W:\WebSiteDev\thornbay\Thornbay\thornbay.muse' with status:success size:40894464 mod Date:Thu Jan 19 07:42:59 GMT+0200 2017 highestUID: 90922
[00:01:41.885] 08:20:46.891 | 00:00:00.186 | 28 | [alwaysOn] | Trying to open file 'W:\WebSiteDev\thornbay\Thornbay\thornbay.muse with size:40894464 mod Date:Thu Jan 19 07:42:59 GMT+0200 2017
[00:01:41.900] 08:20:46.908 | 00:00:00.017 | 29 | [alwaysOn] | Opening file 'W:\WebSiteDev\thornbay\Thornbay\thornbay.muse' with status:success size:40894464 mod Date:Thu Jan 19 07:42:59 GMT+0200 2017 highestUID: 90922
[00:01:44.287] 08:20:49.298 | 00:00:02.390 | 30 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:01:45.317] 08:20:50.326 | 00:00:01.028 | 31 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:45.317] 08:20:50.326 | 00:00:00.000 | 32 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:45.441] 08:20:50.451 | 00:00:00.125 | 33 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:45.441] 08:20:50.451 | 00:00:00.000 | 34 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:48.093] 08:20:53.104 | 00:00:02.653 | 35 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:01:50.527] 08:20:55.535 | 00:00:02.431 | 36 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:50.527] 08:20:55.535 | 00:00:00.000 | 37 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:50.652] 08:20:55.660 | 00:00:00.125 | 38 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:50.652] 08:20:55.660 | 00:00:00.000 | 39 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:50.777] 08:20:55.785 | 00:00:00.125 | 40 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:50.777] 08:20:55.785 | 00:00:00.000 | 41 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:50.901] 08:20:55.910 | 00:00:00.125 | 42 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:50.901] 08:20:55.910 | 00:00:00.000 | 43 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.026] 08:20:56.035 | 00:00:00.125 | 44 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.026] 08:20:56.035 | 00:00:00.000 | 45 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.151] 08:20:56.160 | 00:00:00.125 | 46 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.151] 08:20:56.160 | 00:00:00.000 | 47 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.276] 08:20:56.285 | 00:00:00.125 | 48 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.276] 08:20:56.285 | 00:00:00.000 | 49 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.401] 08:20:56.410 | 00:00:00.125 | 50 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.401] 08:20:56.410 | 00:00:00.000 | 51 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.525] 08:20:56.535 | 00:00:00.125 | 52 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.525] 08:20:56.535 | 00:00:00.000 | 53 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.650] 08:20:56.660 | 00:00:00.125 | 54 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.650] 08:20:56.660 | 00:00:00.000 | 55 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.775] 08:20:56.785 | 00:00:00.125 | 56 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.775] 08:20:56.785 | 00:00:00.000 | 57 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:51.915] 08:20:56.930 | 00:00:00.145 | 58 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:51.915] 08:20:56.930 | 00:00:00.000 | 59 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:01:52.025] 08:20:57.035 | 00:00:00.105 | 60 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:01:52.025] 08:20:57.035 | 00:00:00.000 | 61 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.195] 08:21:47.201 | 00:00:50.166 | 62 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.195] 08:21:47.201 | 00:00:00.000 | 63 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.195] 08:21:47.201 | 00:00:00.000 | 64 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.195] 08:21:47.201 | 00:00:00.000 | 65 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.319] 08:21:47.326 | 00:00:00.125 | 66 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.319] 08:21:47.326 | 00:00:00.000 | 67 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.319] 08:21:47.326 | 00:00:00.000 | 68 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.319] 08:21:47.326 | 00:00:00.000 | 69 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.444] 08:21:47.451 | 00:00:00.125 | 70 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.444] 08:21:47.451 | 00:00:00.000 | 71 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.569] 08:21:47.576 | 00:00:00.125 | 72 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.569] 08:21:47.576 | 00:00:00.000 | 73 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.694] 08:21:47.701 | 00:00:00.125 | 74 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.694] 08:21:47.701 | 00:00:00.000 | 75 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.819] 08:21:47.826 | 00:00:00.125 | 76 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.819] 08:21:47.826 | 00:00:00.000 | 77 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:42.959] 08:21:47.965 | 00:00:00.139 | 78 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:42.959] 08:21:47.965 | 00:00:00.000 | 79 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.068] 08:21:48.076 | 00:00:00.111 | 80 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.068] 08:21:48.076 | 00:00:00.000 | 81 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.193] 08:21:48.201 | 00:00:00.125 | 82 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.193] 08:21:48.201 | 00:00:00.000 | 83 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.318] 08:21:48.326 | 00:00:00.125 | 84 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.318] 08:21:48.326 | 00:00:00.000 | 85 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.443] 08:21:48.451 | 00:00:00.125 | 86 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.443] 08:21:48.451 | 00:00:00.000 | 87 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.567] 08:21:48.576 | 00:00:00.125 | 88 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.567] 08:21:48.576 | 00:00:00.000 | 89 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:43.692] 08:21:48.701 | 00:00:00.125 | 90 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:43.692] 08:21:48.701 | 00:00:00.000 | 91 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:46.531] 08:21:51.536 | 00:00:02.835 | 92 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:02:46.531] 08:21:51.537 | 00:00:00.001 | 93 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:02:46.531] 08:21:51.539 | 00:00:00.002 | 94 | [Web Font API] | Making GET to https://api.typekit.com/muse_v1/families
[00:02:46.843] 08:21:51.852 | 00:00:00.313 | 95 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:02:46.843] 08:21:51.853 | 00:00:00.001 | 96 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:02:48.029] 08:21:53.036 | 00:00:01.183 | 97 | [Web Font API] | onHTTPResponseStatus. Status=200 response for https://api.typekit.com/muse_v1/families
[00:02:48.310] 08:21:53.322 | 00:00:00.286 | 98 | [Web Font API] | onHTTPStatus. Status=200 response for https://api.typekit.com/muse_v1/families
[00:02:48.310] 08:21:53.322 | 00:00:00.000 | 99 | [Web Font API] | onComplete. Got some data and 200 response for https://api.typekit.com/muse_v1/families
[00:02:48.310] 08:21:53.322 | 00:00:00.000 | 100 | [Web Font API] | Elapsed ms: 1783
[00:03:37.762] 08:22:42.770 | 00:00:49.448 | 101 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:37.762] 08:22:42.770 | 00:00:00.000 | 102 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:37.762] 08:22:42.770 | 00:00:00.000 | 103 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:37.762] 08:22:42.770 | 00:00:00.000 | 104 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:37.887] 08:22:42.894 | 00:00:00.124 | 105 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:37.887] 08:22:42.894 | 00:00:00.000 | 106 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:37.887] 08:22:42.894 | 00:00:00.000 | 107 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:37.887] 08:22:42.894 | 00:00:00.000 | 108 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.012] 08:22:43.019 | 00:00:00.125 | 109 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.012] 08:22:43.019 | 00:00:00.000 | 110 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.137] 08:22:43.144 | 00:00:00.125 | 111 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.137] 08:22:43.144 | 00:00:00.000 | 112 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.261] 08:22:43.269 | 00:00:00.125 | 113 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.261] 08:22:43.269 | 00:00:00.000 | 114 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.386] 08:22:43.395 | 00:00:00.126 | 115 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.386] 08:22:43.395 | 00:00:00.000 | 116 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.511] 08:22:43.520 | 00:00:00.125 | 117 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.511] 08:22:43.520 | 00:00:00.000 | 118 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.636] 08:22:43.645 | 00:00:00.125 | 119 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.636] 08:22:43.645 | 00:00:00.000 | 120 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.761] 08:22:43.770 | 00:00:00.125 | 121 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.761] 08:22:43.770 | 00:00:00.000 | 122 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:38.885] 08:22:43.895 | 00:00:00.125 | 123 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:38.885] 08:22:43.895 | 00:00:00.000 | 124 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:39.010] 08:22:44.020 | 00:00:00.125 | 125 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:39.010] 08:22:44.020 | 00:00:00.000 | 126 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:39.135] 08:22:44.145 | 00:00:00.125 | 127 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:39.135] 08:22:44.145 | 00:00:00.000 | 128 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:03:39.260] 08:22:44.271 | 00:00:00.126 | 129 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:03:39.260] 08:22:44.271 | 00:00:00.000 | 130 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:02.722] MuseIMSBusinessCatalyst: amt sign in
[00:04:02.722] Call IMS_fetchAccessToken with params
[00:04:02.722] Client id = BCMuse1
[00:04:02.722] Client secret = 32...23de
[00:04:02.722] User guid = 13...E9@AdobeID
[00:04:02.722] Service guid =
[00:04:02.722] Scope = openid,AdobeID,sao.business_catalyst,creative_cloud
[00:04:02.722] IMS_fetchAccessToken status = 60
[00:04:02.722] MuseIMSTypekit: amt sign in
[00:04:02.722] Client id = MuseTypekit2
[00:04:02.722] Client secret = 23...c9fd
[00:04:02.722] Scope = openid,AdobeID,sao.typekit,creative_cloud
[00:04:02.722] IMS_fetchAccessToken status = 67
[00:04:02.722] MuseIMSHello: amt sign in
[00:04:02.722] Client id = ProjectHello1
[00:04:02.722] Client secret = 2e...8eaa
[00:04:02.722] Scope = openid,AdobeID,creative_cloud
[00:04:02.722] TokenMonitorIdleProc. elapsed=4.0 userGUID=13...E9@AdobeID
[00:04:02.722] ProjectHello1 : IMSStatus=67 signInStatus=3
[00:04:02.722] MuseTypekit2 : IMSStatus=67 signInStatus=3
[00:04:02.722] BCMuse1 : IMSStatus=60 signInStatus=3
[00:04:24.344] 08:23:29.352 | 00:00:45.081 | 131 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.344] 08:23:29.352 | 00:00:00.000 | 132 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.344] 08:23:29.352 | 00:00:00.000 | 133 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.344] 08:23:29.352 | 00:00:00.000 | 134 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.469] 08:23:29.477 | 00:00:00.125 | 135 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.469] 08:23:29.477 | 00:00:00.000 | 136 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.469] 08:23:29.477 | 00:00:00.000 | 137 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.469] 08:23:29.477 | 00:00:00.000 | 138 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.594] 08:23:29.602 | 00:00:00.125 | 139 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.594] 08:23:29.602 | 00:00:00.000 | 140 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.718] 08:23:29.727 | 00:00:00.125 | 141 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.718] 08:23:29.727 | 00:00:00.000 | 142 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.843] 08:23:29.852 | 00:00:00.125 | 143 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.843] 08:23:29.852 | 00:00:00.000 | 144 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:24.968] 08:23:29.977 | 00:00:00.125 | 145 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:24.968] 08:23:29.977 | 00:00:00.000 | 146 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.093] 08:23:30.102 | 00:00:00.125 | 147 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.093] 08:23:30.102 | 00:00:00.000 | 148 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.218] 08:23:30.227 | 00:00:00.125 | 149 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.218] 08:23:30.227 | 00:00:00.000 | 150 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.342] 08:23:30.352 | 00:00:00.125 | 151 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.342] 08:23:30.352 | 00:00:00.000 | 152 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.467] 08:23:30.477 | 00:00:00.125 | 153 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.467] 08:23:30.477 | 00:00:00.000 | 154 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.592] 08:23:30.602 | 00:00:00.125 | 155 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.592] 08:23:30.602 | 00:00:00.000 | 156 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.717] 08:23:30.727 | 00:00:00.125 | 157 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.717] 08:23:30.727 | 00:00:00.000 | 158 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:25.842] 08:23:30.852 | 00:00:00.125 | 159 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:25.842] 08:23:30.852 | 00:00:00.000 | 160 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:37.932] 08:23:42.937 | 00:00:12.085 | 161 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:37.932] 08:23:42.937 | 00:00:00.000 | 162 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:37.932] 08:23:42.937 | 00:00:00.000 | 163 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:37.932] 08:23:42.937 | 00:00:00.000 | 164 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.057] 08:23:43.062 | 00:00:00.125 | 165 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.057] 08:23:43.062 | 00:00:00.000 | 166 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.057] 08:23:43.062 | 00:00:00.000 | 167 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.057] 08:23:43.062 | 00:00:00.000 | 168 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.181] 08:23:43.187 | 00:00:00.125 | 169 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.181] 08:23:43.187 | 00:00:00.000 | 170 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.306] 08:23:43.312 | 00:00:00.125 | 171 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.306] 08:23:43.312 | 00:00:00.000 | 172 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.431] 08:23:43.437 | 00:00:00.125 | 173 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.431] 08:23:43.437 | 00:00:00.000 | 174 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.556] 08:23:43.562 | 00:00:00.125 | 175 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.556] 08:23:43.562 | 00:00:00.000 | 176 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.681] 08:23:43.687 | 00:00:00.125 | 177 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.681] 08:23:43.687 | 00:00:00.000 | 178 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.805] 08:23:43.812 | 00:00:00.125 | 179 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.805] 08:23:43.812 | 00:00:00.000 | 180 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:38.930] 08:23:43.937 | 00:00:00.125 | 181 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:38.930] 08:23:43.937 | 00:00:00.000 | 182 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.024] 08:23:44.039 | 00:00:00.102 | 183 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.024] 08:23:44.040 | 00:00:00.001 | 184 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.133] 08:23:44.145 | 00:00:00.105 | 185 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.133] 08:23:44.145 | 00:00:00.000 | 186 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.258] 08:23:44.270 | 00:00:00.125 | 187 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.258] 08:23:44.270 | 00:00:00.000 | 188 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.258] 08:23:44.270 | 00:00:00.000 | 189 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.258] 08:23:44.270 | 00:00:00.000 | 190 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.383] 08:23:44.395 | 00:00:00.125 | 191 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.383] 08:23:44.395 | 00:00:00.000 | 192 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.383] 08:23:44.395 | 00:00:00.000 | 193 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.383] 08:23:44.395 | 00:00:00.000 | 194 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.507] 08:23:44.520 | 00:00:00.125 | 195 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.507] 08:23:44.520 | 00:00:00.000 | 196 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.632] 08:23:44.645 | 00:00:00.125 | 197 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.632] 08:23:44.645 | 00:00:00.000 | 198 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.757] 08:23:44.769 | 00:00:00.124 | 199 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.757] 08:23:44.769 | 00:00:00.000 | 200 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:39.882] 08:23:44.894 | 00:00:00.125 | 201 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:39.882] 08:23:44.894 | 00:00:00.000 | 202 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.007] 08:23:45.019 | 00:00:00.125 | 203 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.007] 08:23:45.019 | 00:00:00.000 | 204 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.131] 08:23:45.144 | 00:00:00.125 | 205 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.131] 08:23:45.144 | 00:00:00.000 | 206 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.256] 08:23:45.269 | 00:00:00.125 | 207 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.256] 08:23:45.269 | 00:00:00.000 | 208 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.381] 08:23:45.394 | 00:00:00.125 | 209 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.381] 08:23:45.394 | 00:00:00.000 | 210 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.506] 08:23:45.519 | 00:00:00.125 | 211 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.506] 08:23:45.519 | 00:00:00.000 | 212 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.631] 08:23:45.644 | 00:00:00.125 | 213 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.631] 08:23:45.644 | 00:00:00.000 | 214 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:04:40.755] 08:23:45.769 | 00:00:00.125 | 215 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:04:40.755] 08:23:45.769 | 00:00:00.000 | 216 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:05:09.538] AMTRetrieveAdobeID fail
[00:05:09.538] 08:24:14.540 | 00:00:28.771 | 217 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.538] 08:24:14.540 | 00:00:00.000 | 218 | [Typekit API] | Not signed in
[00:05:09.538] 08:24:14.541 | 00:00:00.001 | 219 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.538] 08:24:14.541 | 00:00:00.000 | 220 | [Typekit API] | Not signed in
[00:05:09.553] AMTRetrieveAdobeID fail
[00:05:09.553] 08:24:14.562 | 00:00:00.021 | 221 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.553] 08:24:14.562 | 00:00:00.000 | 222 | [Typekit API] | Not signed in
[00:05:09.553] 08:24:14.562 | 00:00:00.000 | 223 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.553] 08:24:14.562 | 00:00:00.000 | 224 | [Typekit API] | Not signed in
[00:05:09.553] 08:24:14.563 | 00:00:00.001 | 225 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.553] 08:24:14.563 | 00:00:00.000 | 226 | [Typekit API] | Not signed in
[00:05:09.600] AMTRetrieveAdobeID fail
[00:05:09.600] 08:24:14.603 | 00:00:00.040 | 227 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.600] 08:24:14.603 | 00:00:00.000 | 228 | [Typekit API] | Not signed in
[00:05:09.600] 08:24:14.604 | 00:00:00.001 | 229 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.600] 08:24:14.604 | 00:00:00.000 | 230 | [Typekit API] | Not signed in
[00:05:09.631] AMTRetrieveAdobeID fail
[00:05:09.631] 08:24:14.645 | 00:00:00.041 | 231 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.631] 08:24:14.645 | 00:00:00.000 | 232 | [Typekit API] | Not signed in
[00:05:09.631] 08:24:14.646 | 00:00:00.001 | 233 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.631] 08:24:14.646 | 00:00:00.000 | 234 | [Typekit API] | Not signed in
[00:05:09.678] AMTRetrieveAdobeID fail
[00:05:09.678] 08:24:14.687 | 00:00:00.041 | 235 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.678] 08:24:14.687 | 00:00:00.000 | 236 | [Typekit API] | Not signed in
[00:05:09.678] 08:24:14.688 | 00:00:00.001 | 237 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.678] 08:24:14.688 | 00:00:00.000 | 238 | [Typekit API] | Not signed in
[00:05:09.725] AMTRetrieveAdobeID fail
[00:05:09.725] 08:24:14.728 | 00:00:00.040 | 239 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.725] 08:24:14.728 | 00:00:00.000 | 240 | [Typekit API] | Not signed in
[00:05:09.725] 08:24:14.729 | 00:00:00.001 | 241 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.725] 08:24:14.729 | 00:00:00.000 | 242 | [Typekit API] | Not signed in
[00:05:09.756] AMTRetrieveAdobeID fail
[00:05:09.756] 08:24:14.770 | 00:00:00.041 | 243 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.756] 08:24:14.770 | 00:00:00.000 | 244 | [Typekit API] | Not signed in
[00:05:09.756] 08:24:14.770 | 00:00:00.000 | 245 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:09.756] 08:24:14.771 | 00:00:00.001 | 246 | [Typekit API] | Not signed in
[00:05:56.478] AMTRetrieveAdobeID fail
[00:05:56.478] 08:25:01.489 | 00:00:46.718 | 247 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.478] 08:25:01.489 | 00:00:00.000 | 248 | [Typekit API] | Not signed in
[00:05:56.478] 08:25:01.490 | 00:00:00.001 | 249 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.478] 08:25:01.490 | 00:00:00.000 | 250 | [Typekit API] | Not signed in
[00:05:56.509] AMTRetrieveAdobeID fail
[00:05:56.509] 08:25:01.519 | 00:00:00.029 | 251 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.509] 08:25:01.519 | 00:00:00.000 | 252 | [Typekit API] | Not signed in
[00:05:56.509] 08:25:01.519 | 00:00:00.000 | 253 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.509] 08:25:01.520 | 00:00:00.001 | 254 | [Typekit API] | Not signed in
[00:05:56.509] 08:25:01.520 | 00:00:00.000 | 255 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.509] 08:25:01.520 | 00:00:00.000 | 256 | [Typekit API] | Not signed in
[00:05:56.556] AMTRetrieveAdobeID fail
[00:05:56.556] 08:25:01.561 | 00:00:00.041 | 257 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.556] 08:25:01.561 | 00:00:00.000 | 258 | [Typekit API] | Not signed in
[00:05:56.556] 08:25:01.562 | 00:00:00.001 | 259 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.556] 08:25:01.562 | 00:00:00.000 | 260 | [Typekit API] | Not signed in
[00:05:56.587] AMTRetrieveAdobeID fail
[00:05:56.587] 08:25:01.602 | 00:00:00.040 | 261 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.587] 08:25:01.602 | 00:00:00.000 | 262 | [Typekit API] | Not signed in
[00:05:56.587] 08:25:01.603 | 00:00:00.001 | 263 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.587] 08:25:01.603 | 00:00:00.000 | 264 | [Typekit API] | Not signed in
[00:05:56.634] AMTRetrieveAdobeID fail
[00:05:56.634] 08:25:01.644 | 00:00:00.041 | 265 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.634] 08:25:01.644 | 00:00:00.000 | 266 | [Typekit API] | Not signed in
[00:05:56.634] 08:25:01.645 | 00:00:00.001 | 267 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.634] 08:25:01.645 | 00:00:00.000 | 268 | [Typekit API] | Not signed in
[00:05:56.681] AMTRetrieveAdobeID fail
[00:05:56.681] 08:25:01.686 | 00:00:00.041 | 269 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.681] 08:25:01.686 | 00:00:00.000 | 270 | [Typekit API] | Not signed in
[00:05:56.681] 08:25:01.687 | 00:00:00.001 | 271 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.681] 08:25:01.687 | 00:00:00.000 | 272 | [Typekit API] | Not signed in
[00:05:56.728] AMTRetrieveAdobeID fail
[00:05:56.728] 08:25:01.737 | 00:00:00.050 | 273 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.728] 08:25:01.737 | 00:00:00.000 | 274 | [Typekit API] | Not signed in
[00:05:56.728] 08:25:01.738 | 00:00:00.001 | 275 | [alwaysOn] | Error - IMS : No AdobeID signed in
[00:05:56.728] 08:25:01.738 | 00:00:00.000 | 276 | [Typekit API] | Not signed in
[00:06:18.100] MuseIMSBusinessCatalyst: amt sign in
[00:06:18.100] Call IMS_fetchAccessToken with params
[00:06:18.100] Client id = BCMuse1
[00:06:18.100] Client secret = 32...23de
[00:06:18.100] User guid = 13...E9@AdobeID
[00:06:18.100] Service guid =
[00:06:18.100] Scope = openid,AdobeID,sao.business_catalyst,creative_cloud
[00:06:18.116] IMS_fetchAccessToken status = 67
[00:06:18.116] MuseIMSTypekit: amt sign in
[00:06:18.116] Call IMS_fetchAccessToken with params
[00:06:18.116] Client id = MuseTypekit2
[00:06:18.116] Client secret = 23...c9fd
[00:06:18.116] User guid = 13...E9@AdobeID
[00:06:18.116] Service guid =
[00:06:18.116] Scope = openid,AdobeID,sao.typekit,creative_cloud
[00:06:18.116] MuseIMSHello: amt sign in
[00:06:18.116] Client id = ProjectHello1
[00:06:18.116] Client secret = 2e...8eaa
[00:06:18.116] Scope = openid,AdobeID,creative_cloud
[00:06:18.116] TokenMonitorIdleProc. elapsed=6.3 userGUID=13...E9@AdobeID
[00:06:18.116] ProjectHello1 : IMSStatus=67 signInStatus=3
[00:06:18.116] MuseTypekit2 : IMSStatus=67 signInStatus=3
[00:06:18.116] BCMuse1 : IMSStatus=67 signInStatus=3
[00:06:58.473] MuseIMSBusinessCatalyst: amt sign in
[00:06:58.473] Call IMS_fetchAccessToken with params
[00:06:58.473] Client id = BCMuse1
[00:06:58.473] Client secret = 32...23de
[00:06:58.473] User guid = 13...E9@AdobeID
[00:06:58.473] Service guid =
[00:06:58.473] Scope = openid,AdobeID,sao.business_catalyst,creative_cloud
[00:06:58.473] IMS_fetchAccessToken status = 67
[00:06:58.473] MuseIMSTypekit: amt sign in
[00:06:58.473] Client id = MuseTypekit2
[00:06:58.473] Client secret = 23...c9fd
[00:06:58.473] Scope = openid,AdobeID,sao.typekit,creative_cloud
[00:06:58.473] MuseIMSHello: amt sign in
[00:06:58.473] Client id = ProjectHello1
[00:06:58.473] Client secret = 2e...8eaa
[00:06:58.473] Scope = openid,AdobeID,creative_cloud
[00:06:58.489] IMS_fetchAccessToken status = 67
[00:07:18.145] TokenMonitorIdleProc. elapsed=7.3 userGUID=13...E9@AdobeID
[00:07:18.145] ProjectHello1 : IMSStatus=67 signInStatus=3
[00:07:18.145] MuseTypekit2 : IMSStatus=67 signInStatus=3
[00:07:18.145] BCMuse1 : IMSStatus=67 signInStatus=3
[00:07:28.129] 08:26:33.145 | 00:01:31.407 | 277 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.129] 08:26:33.145 | 00:00:00.000 | 278 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.129] 08:26:33.145 | 00:00:00.000 | 279 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.129] 08:26:33.145 | 00:00:00.000 | 280 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.254] 08:26:33.270 | 00:00:00.125 | 281 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.254] 08:26:33.270 | 00:00:00.000 | 282 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.254] 08:26:33.270 | 00:00:00.000 | 283 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.254] 08:26:33.270 | 00:00:00.000 | 284 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.378] 08:26:33.395 | 00:00:00.125 | 285 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.378] 08:26:33.395 | 00:00:00.000 | 286 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.503] 08:26:33.520 | 00:00:00.125 | 287 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.503] 08:26:33.520 | 00:00:00.000 | 288 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.628] 08:26:33.645 | 00:00:00.125 | 289 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.628] 08:26:33.645 | 00:00:00.000 | 290 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.753] 08:26:33.770 | 00:00:00.125 | 291 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.753] 08:26:33.770 | 00:00:00.000 | 292 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:28.878] 08:26:33.895 | 00:00:00.125 | 293 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:28.878] 08:26:33.895 | 00:00:00.000 | 294 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.034] 08:26:34.037 | 00:00:00.142 | 295 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.034] 08:26:34.038 | 00:00:00.001 | 296 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.143] 08:26:34.145 | 00:00:00.107 | 297 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.143] 08:26:34.145 | 00:00:00.000 | 298 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.268] 08:26:34.270 | 00:00:00.125 | 299 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.268] 08:26:34.270 | 00:00:00.000 | 300 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.392] 08:26:34.395 | 00:00:00.125 | 301 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.392] 08:26:34.395 | 00:00:00.000 | 302 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.517] 08:26:34.520 | 00:00:00.125 | 303 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.517] 08:26:34.520 | 00:00:00.000 | 304 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:07:29.642] 08:26:34.645 | 00:00:00.125 | 305 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:07:29.642] 08:26:34.645 | 00:00:00.000 | 306 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:09.672] 08:27:14.686 | 00:00:40.041 | 307 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:09.672] 08:27:14.686 | 00:00:00.000 | 308 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:09.672] 08:27:14.686 | 00:00:00.000 | 309 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:09.672] 08:27:14.687 | 00:00:00.001 | 310 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:09.797] 08:27:14.812 | 00:00:00.125 | 311 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:09.797] 08:27:14.812 | 00:00:00.000 | 312 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:09.797] 08:27:14.812 | 00:00:00.000 | 313 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:09.797] 08:27:14.812 | 00:00:00.000 | 314 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:09.921] 08:27:14.936 | 00:00:00.124 | 315 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:09.921] 08:27:14.936 | 00:00:00.000 | 316 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.046] 08:27:15.061 | 00:00:00.125 | 317 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.046] 08:27:15.061 | 00:00:00.000 | 318 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.296] 08:27:15.311 | 00:00:00.125 | 321 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.296] 08:27:15.311 | 00:00:00.000 | 322 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.421] 08:27:15.436 | 00:00:00.125 | 323 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.421] 08:27:15.436 | 00:00:00.000 | 324 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.545] 08:27:15.561 | 00:00:00.125 | 325 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.545] 08:27:15.561 | 00:00:00.000 | 326 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.670] 08:27:15.686 | 00:00:00.125 | 327 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.670] 08:27:15.686 | 00:00:00.000 | 328 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.795] 08:27:15.811 | 00:00:00.125 | 329 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.795] 08:27:15.811 | 00:00:00.000 | 330 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:10.920] 08:27:15.936 | 00:00:00.125 | 331 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:10.920] 08:27:15.936 | 00:00:00.000 | 332 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:11.045] 08:27:16.061 | 00:00:00.125 | 333 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:11.045] 08:27:16.061 | 00:00:00.000 | 334 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:11.169] 08:27:16.186 | 00:00:00.125 | 335 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:11.169] 08:27:16.186 | 00:00:00.000 | 336 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
[00:08:16.286] 08:27:21.289 | 00:00:05.103 | 337 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:08:16.286] 08:27:21.289 | 00:00:00.000 | 338 | [MuseIMSManager] | Typekit Level (Numeric): -1
[00:08:16.411] 08:27:21.427 | 00:00:00.138 | 339 | [alwaysOn] | Error - IMS : ErrorCode=67 ErrorMessage=
[00:08:16.411] 08:27:21.427 | 00:00:00.000 | 340 | [Typekit API] | Bad IMS status SHARED_UNKNOWN_ERROR 67
