Hey, guys, so I had this pretty weak PC that I was working with a month ago, I was working with adobe premiere and the performance was really poor. So I decided to save some money and buy a new PC so I can finally work with Premiere and After Effects without any lag. So I saved up 600 bucks and bought a PC with these Specs:
Hard: Sata 1TB
CPU: AMD FX 8300 (I know I could've bought Intel i7..)
RAM: 8GB (Gonna add more ram soon)
VIDEO CARD: DUAL GTX 1080 03G
Then I installed Premiere, it works fine, could be a bit faster, but its not that bad. But then I opened the AFTER EFFECTS.... I just pasted some audio into the project and decided to play it.The song alone can't even play in the same speed that it supposed to play, the audio is super laggy, choppy. Im not even talking about adding effects on images and stuff. And the rendering bar is fully green in the timeline, so it has loaded, but it still plays like that. Ive set the preview quality to "Quarter" and it still plays like that. I've watched almost every video about increasing the performance in youtube, did the memory settings thing and other stuff. Is After Effects seriously that hard to run? Is this normal? Because Premiere can handle the same thing with no problems. If that is the case then after effects is optimized very bad. But I still have hope. Can you help me, guys?
After effects is designed to playback cached frames in real-time. meaning it is designed to render the frames to memory before it can play them back in real time. definitely not the same experience you might have with a video editor like premiere. in the latest version, the ability to playback in real-time even non cached frames was improved significantly and was described t
...Copy link to clipboard
Um, how would you describe the amount of time you've spent working with After Effects? Months? Weeks? Days? Hours?
A few Days with After Effects. Well, I haven't really worked with it, just tried to figure out how to speed things up haha. I've worked with Premiere for about 6 months though, so I know basic stuff about video editing.
sauliuss43758650 wrote:
...I haven't really worked with it... I've worked with Premiere for about 6 months though, so I know basic stuff about video editing.
You're in for a big surprise then. AE doesn't work anything like PP! Read Roei's explanation.
AE is also quirky and EXTREMELY complicated -- far more so than PP -- so you need training in the basics or you'll get lost and frustrated. Not good.
Fortunately there's help! Go here:
Avoid AE tutorials done by high school kids on YouTube -- even on good days those guys can't find their posteriors in the dark using both hands. Get your knowledge from the pros.
After effects is designed to playback cached frames in real-time. meaning it is designed to render the frames to memory before it can play them back in real time. definitely not the same experience you might have with a video editor like premiere. in the latest version, the ability to playback in real-time even non cached frames was improved significantly and was described that "Most video footage can now play back in real-time before effects are applied, without waiting for ....
if the rendering bar is green it means the frames are cached to RAM and should playback smoothly. if you are experiencing anything different please share more information:
here are some articles you might find useful. make sure you know what to expect with Ae because it's not intuitive:
Improve performance in After Effects
