1)Created on RoboHelp 7.0.2 (from trial version) and
generated for UNIX.
2)Transferred WebHelp to USB Drive.
3) WebHelp can be started from USB Drive on UNIX platform.
(However, TOC in left-hand frame does not correctly size
vertically--limited to about 2 inches )
4) Content seems to "continually refresh" (it just flashes
progress bar...never see page) when WebHelp transferred to UNIX
(Solaris 10 Update5 with Firefox 2.0.0.11) from USB Drive and
activated from Desktop by opening initial topic.
When run from USB Thumb Drive:
Contents Tab: does not size Vertically and there is NO
Horizontal Scroll Bar.
Index, Search & Glossary Tabs show both Vertical and
Horizontal Scroll Bars when selected.
So the issue is that the window covers a certain depth but
the TOC only goes down a small proportion of that and does not
continue and display the rest of the TOC?
In a generated project the TOC displays within the navigation
pane as expected...but the navigation pane is somehow "limited" to
the initial TOC display with none of the 4 books open.
(Firefox/UNIX)
When same project is viewed on Windows Browser the TOC is
capable of expanding the full height of the navigation pane on the
left side (with all 4 books open and easilly viewed)
It seems to have something to do with the "generated" scripts
(?DHTML?) If I manually edit and add an entry to the TOC the topic
is just out of view at the bottom "limit" of the navigation pane.
The navigation pane appears to be full height on the left
side.....however the TOC will only display within the original
height with all Books closed? It is however nice enough to provide
a vertical scroll-bar on the right-hand side of the navigation
pane...so I can scroll down to look at opened books.....:)
