My configuration is Windows 10 + Creative Cloud CC (2017)
I have a big problem on all the software (photoshop, illustrator, indesign...).
When i want to drag and drop an element like picture or block text, the mouse "loose" the element.
It's really annoying.
I search many times a solution on web but i don't find something who solve my problem.
Someone has an idea ?
Thank you for your help.
if your mouse uses batteries, replace the batteries.
I haven't batteries on my mouse...
try a different mouse to see if you can eliminate your mouse as the problem's cause.
I have try 5 different mouse. Same problem
open photoshop, press alt and then drag an object from a cc library to the canvas.
any problem?
The problem is for all the manipulation like change layer position, change object position in canvas...
I have search on the web and may be it's windows 10 problem. The only solution i have found it's to push escape many times and it work for a few minutes.
i have win 10 and i don't have that problem.
Moving this discussion to the File Hosting, Syncing, and Collaboration forum.
i confirm the same issue, since i installed windows 10 professional 64bit in my workstation with CC2017.
Photoshop Premiere Illustrator Audition, drag and drop doesn't work. only After Effects works fine.
I have the UAC deactivated, but nothing works.
i found some solution on youtube, they prompt you to change one value to registry editor. This fixs the problem, but screws windows operations (errors like you need to login with administrator privileges etc), so i revert back to the default value.
I think it is related to windows 10, since i have the same issue in 3dsmax 2017.
i have also contacted Microsoft live (automatic?) chat.
they prompted me to try few different solutions such as:
uninstall /install cc2017
create new user and run programms from the new user
get the latest updates
unfortunately nothing worked.
if anyone has a solution to this problem please share it with us.
Sorry to hear about your difficulties.
I wondered if this was more of an issue with Windows 10 rather than with Adobe
Please see this link for reference
how to fix drag and drop in windows 10? - Microsoft Community
Could you test if it happens in non-Adobe apps too?
- Dave
