When I go to link something in InDesign, it just pops to the folder and doesn’t show the path (even though I have it selected to show the path)… Not ideal when I have to relink a ton of images in a portfolio
Closing out of the window and relinking will sometimes bring the full path, but it is hit or miss. This started happening after the update to MacOS Sierra
You are talking about the top line of your screen shot, where it says Place and not Relink and the path, as expected?
Does deleting prefs help?
Troubleshooting 101: Replace, or "trash" your InDesign preferences
If not, maybe you want to file a bug report:
not quite, you see how you have your path documents/aeris, well there is a longer path to my screen shot but instead it just shows the one folder.
I tried to delete prefs (as per my other question on the forum but the shift+control+option+command wouldn't prompt it (I've tried the same thing on CS 6 on another machine and I deleted prefs right away so it isn't something I am doing wrong).
Ah, I see it now. I'm still on El Capitan because of the issues with the Sierra upgrade, so maybe it's Sierra?
Did you try the alternate way to delete prefs? If you read through that link, you can locate and delete files to accomplish the same thing as pressing all the keys.
Otherwise, it's time to report it as a bug.
If this is what you mean, I don't seem to have that problem with Sierra and InDesign CC 2017. I'm seeing a full path:
ah no, it's more in the folder views, sometimes it shows just one folder or the other paths leading to the one folder.
I'm still not understanding what you're meaning. What do you mean? Can you mark it on your screen capture?
I've been regularly using InDesign on two computers with Sierra for some time and haven't observed anything unusual.
So column view is selected and only the folder "Final Marketing Photoshop.." is showing in the column view, there should be the other folder before it on the other columns
I'm still not seeing a problem. You know you can click on the Enclosing Folder icon above, and see the hierarchy of files so you can navigate back up the hierarchy (shown below)?
ah yes i do know that, i just wanted to see if it were a bug or not, since currently it's not acting normal.
Did you ever get it resovled? I'm having the smae issue
