17 Replies Latest reply on Jan 23, 2017 4:05 PM by DanTull
    Adobe character animator internal error code assertion failed!
    simrick Level 1
      Hello there, I have tried to uninstall and reinstall adobe character animator and it still keeps coming up.
      When I open the software it's fine but when I go to anything like "new illustrator puppet" or "new Photoshop puppet" it comes up with this error twice.
      Adobe character animator internal error code (1033274218+19) assertion failed!
      I'm using a quite new MSI laptop with windows 10, core i7 and 16GB of Ram. This problem does't come up on my tower computer and it's using windows 8.1 with 16GB of RAM.
      I have tried disabling the camera on my laptop to see if it would still come up as my tower computer does not have a camera and it still comes up twice.
      Any help would be appreciated.
        • 1. Re: Adobe character animator internal error code assertion failed!
          oksamurai Employee Moderator
          Are you able to do anything at all or does this always show up? File > Import with a PSD, opening the interactive tutorial from the welcome panel, or open an existing .puppet or .chproj file from the examples? In your Documents folder there should be an Adobe folder with CH stuff in it - if you delete it does that help?
          Yeah, if it's opening up okay and then no puppets are loading, it feels like it might be a camera, microphone, or hardware conflict of some sort. Are any other programs running in the background that could possibly conflict? Can you post a screenshot or more detailed specs about your machine?
          • 2. Re: Adobe character animator internal error code assertion failed!
            simrick Level 1
            Thanks for the reply,
                                             I have been testing everything and the way it starts seems to be only when I open a new puppet in illustrator, after that; even when I than go out of illustrator and remove all projects/scenes that error keeps coming up even when hitting "File" or "Edit"?
            If I restart the program and leave the default puppet up it seems to work fine, should I uninstall illustrator maybe?
            P.S It works fine on Photoshop and with both my PC mic and my studio mic.
            • 3. Re: Adobe character animator internal error code assertion failed!
              Okay so it's only happening with AI files? Strange. I'm assuming you're up to date with the latest 2017 version...
              The Puppet Pack I put together has a couple of AI files like Red Monster and Wilk - are you getting the same error when selecting those? I'm trying to figure out if this is just something weird with the blue template character you have or something more.
              • 4. Re: Adobe character animator internal error code assertion failed!
                simrick Level 1
                I have 2017 and I just saw that it has an update, so I updated and shut down my computer and turned it back on. both before and after I did this when I opened that file you give me it came up with that same error from before.
                • 5. Re: Adobe character animator internal error code assertion failed!
                  simrick Level 1
                  I also tried removing the .AI files from that project you give me and it opened fine with out them.
                  • 6. Re: Adobe character animator internal error code assertion failed!
                    Asking the team and it looks like this might be a bug - looking into it now. Thanks for reporting!
                    • 7. Re: Adobe character animator internal error code assertion failed!
                      DanTull Adobe Employee
                      I was able to find what I think is the same assert (with full identifier 1033274218:975+19) which corresponds to an error detected when trying to format/save data into the Ch project when the locale of the app has been set to something surprising.
                      This might suggest a third party library being loaded when Character Animator loads the code it uses to access Adobe Illustrator files. It may also suggest a preference (maybe for number formatting or other locale specific options) causing the locale to be changed.
                      One thing that might help narrow it down would be to collect a list of the DLLs loaded into the Character Animator process before and after triggering the error. I haven't used it, but this tool seems like it should get the info: ListDLLs
                      This might be an easier way: https://support.microsoft.com/en-us/help/970920/using-process-explorer-to-list-dlls-runnin g-under-the-outlook.exe-proces…  (the instructions should mostly be the same except we'd be looking for Character Animator.exe instead of Outlook.exe)
                      I have a bit more digging I can do, but hopefully that provides some clues as to what might be happening here.
                      Dan Tull
                      • 8. Re: Adobe character animator internal error code assertion failed!
                        simrick Level 1
                        ProcessCPUPrivate BytesWorking SetPIDDescriptionCompany Name
                        System Idle Process90.460 K4 K0
                        System0.47128 K136 K4
                        Interrupts0.680 K0 Kn/aHardware Interrupts and DPCs
                        smss.exe376 K1,012 K528
                        Memory Compression172 K52,028 K3552
                        csrss.exe< 0.011,592 K4,180 K712
                        wininit.exe1,060 K4,964 K844
                        services.exe3,392 K7,468 K920
                          svchost.exe< 0.019,696 K24,468 K104Host Process for Windows ServicesMicrosoft Corporation
                           unsecapp.exe1,616 K6,588 K3940
                           WmiPrvSE.exe3,900 K12,908 K4212
                           RuntimeBroker.exe28,284 K59,988 K5900Runtime BrokerMicrosoft Corporation
                           ShellExperienceHost.exeSuspended32,544 K72,872 K6244Windows Shell Experience HostMicrosoft Corporation
                           SearchUI.exeSuspended81,748 K138,896 K6300Search and Cortana applicationMicrosoft Corporation
                           SkypeHost.exeSuspended35,644 K58,120 K7056Microsoft Skype PreviewMicrosoft Corporation
                           RemindersServer.exeSuspended10,444 K19,736 K7140Reminders WinRT OOP ServerMicrosoft Corporation
                           SettingSyncHost.exe10,416 K10,364 K5604Host Process for Setting SynchronizationMicrosoft Corporation
                           unsecapp.exe4,700 K9,788 K9528Sink to receive asynchronous callbacks for WMI client applicationMicrosoft Corporation
                           nvspcaps64.exe< 0.0110,448 K29,772 K10076NVIDIA Capture ServerNVIDIA Corporation
                            NVIDIA Share.exe21,676 K36,040 K9508NVIDIA ShareNVIDIA Corporation
                             NVIDIA Share.exe41,348 K53,940 K6732NVIDIA ShareNVIDIA Corporation
                           explorer.exe< 0.0123,548 K56,576 K10852Windows ExplorerMicrosoft Corporation
                           dllhost.exe5,304 K12,240 K6932COM SurrogateMicrosoft Corporation
                           ApplicationFrameHost.exe23,168 K37,104 K9296Application Frame HostMicrosoft Corporation
                           Microsoft.Photos.exeSuspended177,716 K229,972 K12864
                           Video.UI.exeSuspended14,412 K26,620 K364Video ApplicationMicrosoft Corporation
                           SkypeApp.exeSuspended28,212 K57,412 K9012SkypeAppMicrosoft
                           SystemSettings.exeSuspended13,200 K43,740 K14644SettingsMicrosoft Corporation
                           Music.UI.exeSuspended16,160 K29,064 K7944Music ApplicationMicrosoft Corporation
                           smartscreen.exe8,628 K15,036 K13372SmartScreenMicrosoft Corporation
                           dllhost.exe4,852 K9,692 K6588COM SurrogateMicrosoft Corporation
                          svchost.exe< 0.016,396 K11,780 K396Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe7,124 K19,988 K620Host Process for Windows ServicesMicrosoft Corporation
                           WUDFHost.exe< 0.011,296 K5,660 K1164
                           dasHost.exe3,312 K11,596 K2296
                           WUDFHost.exe1,976 K8,052 K12908
                          svchost.exe14,668 K27,496 K840Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe< 0.0122,584 K54,020 K1176Host Process for Windows ServicesMicrosoft Corporation
                           sihost.exe9,272 K25,868 K6600Shell Infrastructure HostMicrosoft Corporation
                           taskhostw.exe9,644 K19,736 K6508Host Process for Windows TasksMicrosoft Corporation
                           SynTPEnh.exe0.338,508 K7,308 K6500Synaptics TouchPad 64-bit EnhancementsSynaptics Incorporated
                           muachost.exe1,976 K1,120 K6820
                          WRSA.exe0.0529,592 K9,416 K1248Webroot SecureAnywhereWebroot
                           WRSA.exe0.057,836 K576 K6952Webroot SecureAnywhereWebroot
                          svchost.exe18,408 K31,120 K1316Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe12,452 K29,260 K1436Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe0.017,228 K17,984 K1532Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe4,120 K11,876 K1760Host Process for Windows ServicesMicrosoft Corporation
                          igfxCUIService.exe1,800 K8,704 K1896igfxCUIService ModuleIntel Corporation
                          svchost.exe2,440 K9,792 K1976Host Process for Windows ServicesMicrosoft Corporation
                           audiodg.exe30,896 K33,020 K6956
                          svchost.exe4,012 K13,216 K1340Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe6,136 K17,708 K2092Host Process for Windows ServicesMicrosoft Corporation
                           wlanext.exe5,060 K16,464 K2452
                            conhost.exe1,152 K4,988 K2468
                          AvastSvc.exe< 0.0188,008 K40,772 K2212avast! ServiceAVAST Software
                          svchost.exe4,232 K13,000 K2232Host Process for Windows ServicesMicrosoft Corporation
                          spoolsv.exe5,668 K14,516 K2600Spooler SubSystem AppMicrosoft Corporation
                          svchost.exe0.0217,116 K35,188 K3024Host Process for Windows ServicesMicrosoft Corporation
                          OfficeClickToRun.exe37,424 K56,268 K3040Microsoft Office Click-to-Run (SxS)Microsoft Corporation
                          ibtsiva.exe796 K3,928 K3048Intel(R) Wireless Bluetooth(R) iBtSiva ServiceIntel Corporation
                          EvtEng.exe4,876 K13,412 K2056Intel(R) PROSet/Wireless Event Log ServiceIntel(R) Corporation
                          MsiTrueColorService.exe< 0.011,068 K5,492 K3144Msi True Color servicePortrait Displays, Inc.
                           MsiTrueColorHelper.exe736 K3,600 K9472
                          TuneUpUtilitiesService64.exe0.0413,852 K29,344 K3156AVG PC TuneUp ServiceAVG Technologies
                           TuneUpUtilitiesApp64.exe0.016,700 K18,468 K6656AVG PC TuneUpAVG Technologies
                          WTSrv.exe1,060 K4,812 K3164
                          nvcontainer.exe0.048,704 K22,684 K3192NVIDIA ContainerNVIDIA Corporation
                           nvcontainer.exe0.0116,044 K29,392 K6676NVIDIA ContainerNVIDIA Corporation
                          MSIService.exe1,672 K8,624 K3208MSI SCM ServiceMicro-Star International Co., Ltd.
                          NVDisplay.Container.exe2,520 K9,924 K3216NVIDIA ContainerNVIDIA Corporation
                           nvxdsync.exe0.019,380 K24,296 K4900
                            nvtray.exe3,300 K12,392 K9016NVIDIA SettingsNVIDIA Corporation
                          pnusbvirtualhubwssrv.exe< 0.011,868 K5,504 K3236Virtual USB Hub Main moduleDell Inc.
                          NvTelemetryContainer.exe< 0.016,736 K13,436 K3248NVIDIA ContainerNVIDIA Corporation
                          nvwirelesscontroller.exe2,352 K8,816 K3260NVIDIA Wireless Controller ServiceNVIDIA Corporation
                          svchost.exe2,044 K8,384 K3296Host Process for Windows ServicesMicrosoft Corporation
                          RegSrvc.exe1,876 K8,976 K3312Intel(R) PROSet/Wireless Registry ServiceIntel(R) Corporation
                          ZeroConfigService.exe4,604 K16,496 K3344Intel® PROSet/Wireless Zero Configure ServiceIntel® Corporation
                          svchost.exe< 0.018,876 K21,436 K3512Host Process for Windows ServicesMicrosoft Corporation
                          svchost.exe12,376 K41,180 K6580Host Process for Windows ServicesMicrosoft Corporation
                          PresentationFontCache.exe27,608 K22,564 K6540PresentationFontCache.exeMicrosoft Corporation
                          SearchIndexer.exe< 0.0147,020 K52,984 K7028Microsoft Windows Search IndexerMicrosoft Corporation
                          IAStorDataMgrSvc.exe30,004 K51,228 K11248IAStorDataSvcIntel Corporation
                          wmpnetwk.exe6,380 K21,664 K10152Windows Media Player Network Sharing ServiceMicrosoft Corporation
                          IntelCpHeciSvc.exe1,656 K7,188 K13712IntelCpHeciSvc ExecutableIntel Corporation
                          isa.exe9,204 K12,820 K3448Intel(R) Security AssistIntel Corporation
                        lsass.exe6,724 K16,696 K928Local Security Authority ProcessMicrosoft Corporation
                        csrss.exe0.562,328 K6,740 K852
                        winlogon.exe1,996 K9,460 K740
                        dwm.exe0.7366,764 K98,436 K1028
                        fontdrvhost.exe812 K2,960 K10244
                        explorer.exe1.39108,976 K159,444 K7184Windows ExplorerMicrosoft Corporation
                        RtkNGUI64.exe7,296 K14,620 K6424Realtek HD Audio ManagerRealtek Semiconductor
                        MsiTrueColor.exe0.055,688 K14,636 K9364MSI True ColorPortrait Displays, Inc.
                        SCM.exe0.0459,000 K60,268 K9572SCMMSI
                        OneDrive.exe16,452 K41,708 K9840Microsoft OneDriveMicrosoft Corporation
                        flux.exe0.0117,344 K18,016 K9952f.luxFlux Software LLC
                        IDMan.exe18,880 K46,920 K10104Internet Download Manager (IDM)Tonec Inc.
                          IDMIntegrator64.exe0.046,172 K13,656 K1292IDM Integration moduleInternet Download Manager, Tonec Inc.
                          IEMonitor.exe0.021,628 K8,172 K9332Internet Download Manager agent for click monitoring in IE-based browsersTonec Inc.
                        SteelSeriesEngine3.exe< 0.0127,548 K40,600 K7240SteelSeries Engine 3 CoreSteelSeries ApS
                        MEGAsync.exe17,872 K36,692 K856MEGAsyncMega Limited
                        Rainmeter.exe2.9845,972 K64,372 K7776
                          chrome.exe0.10103,476 K154,764 K11584Google ChromeGoogle Inc.
                           chrome.exe0.033,268 K12,356 K11664Google ChromeGoogle Inc.
                           chrome.exe0.046,452 K15,640 K11740Google ChromeGoogle Inc.
                           chrome.exe0.0374,624 K88,636 K11952Google ChromeGoogle Inc.
                           chrome.exe147,448 K148,964 K8848Google ChromeGoogle Inc.
                           chrome.exe28,576 K36,684 K12388Google ChromeGoogle Inc.
                           chrome.exe36,444 K41,656 K12396Google ChromeGoogle Inc.
                           chrome.exe0.01423,932 K468,540 K14548Google ChromeGoogle Inc.
                           chrome.exe0.05131,016 K147,608 K5620Google ChromeGoogle Inc.
                           chrome.exe< 0.0164,536 K77,688 K10908Google ChromeGoogle Inc.
                        Character Animator.exe0.13242,276 K197,864 K13792Character Animator CC BetaAdobe Systems Incorporated
                          dynamiclinkmanager.exe8,988 K17,740 K5964Adobe Dynamic Link Manager 1.0Adobe Systems Incorporated
                        procexp.exe4,176 K11,084 K1008Sysinternals Process ExplorerSysinternals - www.sysinternals.com
                          procexp64.exe1.4938,012 K74,528 K3540Sysinternals Process ExplorerSysinternals - www.sysinternals.com
                        igfxEM.exe5,860 K14,104 K7772igfxEM ModuleIntel Corporation
                        igfxHK.exe5,360 K11,472 K7876igfxHK ModuleIntel Corporation
                        igfxTray.exe5,748 K12,772 K7988
                        SynTPHelper.exe908 K776 K8888
                        AvastUI.exe0.0216,424 K25,192 K2852avast! AntivirusAVAST Software
                        ProductUpdater.exe0.0131,148 K37,744 K8224ProductUpdater
                        NVIDIA Web Helper.exe0.0335,980 K53,216 K8516NVIDIA Web Helper ServiceNode.js
                        conhost.exe4,880 K7,992 K5356Console Window HostMicrosoft Corporation
                        PNUSBCLITRAY.exe1,336 K6,284 K9196Virtual USB Hub Client System TrayDell Inc.
                        pntray.exe< 0.011,204 K6,352 K9268Quest System TrayDell Inc.
                        IAStorIcon.exe21,816 K36,408 K11500IAStorIconIntel Corporation
                        HDDtoGOLaunch.exe3,756 K7,724 K13676
                        Process: Character Animator.exe Pid: 13792
                        NameDescriptionCompany NamePath
                        {AFBF9F1A-8EE8-4C77-AF34-C647E37CA0D9}.1.ver0x0000000000000044.dbC:\Users\Patrick\AppData\Local\Microsoft\Windows\Caches\{AFBF9F1A-8EE8-4C77-AF34-C647E37CA 0D9}.1.ver0x0000000000000044.db
                        ACE.dllAdobe Color EngineAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\ACE.dll
                        adobe_caps.dllAdobe CAPS DLLAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\adobe_caps.dll
                        AdobeLinguistic.dllLinguistic LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeLinguistic.dll
                        AdobePDFL.dllAdobe PDF LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePDFL.dll
                        AdobePIP.dllAdobe Product Improvement ProgramAdobe Systems, IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePIP.dll
                        AdobePSL.dllAdobePSLAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePSL.dll
                        AdobeXMP.dllAdobe XMP Core 5.6-c067 ( 64 bit )Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeXMP.dll
                        AdobeXMPFiles.dllAdobe XMP Files 5.6-f146 ( 64 bit )Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeXMPFiles.dll
                        advapi32.dllAdvanced Windows 32 Base APIMicrosoft CorporationC:\Windows\System32\advapi32.dll
                        AgKernel.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AgKernel.dll
                        AGM.dllAdobe Graphics ManagerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AGM.dll
                        aif_core.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\aif_core.dll
                        aif_ogl.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\aif_ogl.dll
                        AILib.dllAdobe Illustrator CCAdobe Systems Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AILib.dll
                        AmioAiff.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioAiff.amio
                        AmioMp3.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioMp3.amio
                        AmioWav.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioWav.amio
                        amtlib.dllAMT LicensingAdobe Systems, IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\amtlib.dll
                        ARE.dllAdobe Raster ExpressAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\ARE.dll
                        AuAudioComponents.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuAudioComponents.dll
                        AuBackEnd.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuBackEnd.dll
                        AuCore.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuCore.dll
                        AudioSes.dllAudio SessionMicrosoft CorporationC:\Windows\System32\AudioSes.dll
                        avicap32.dllAVI Capture window classMicrosoft CorporationC:\Windows\System32\avicap32.dll
                        avicap32.dll.muiAVI Capture window classMicrosoft CorporationC:\Windows\System32\en-US\avicap32.dll.mui
                        avifil32.dllMicrosoft AVI File support libraryMicrosoft CorporationC:\Windows\System32\avifil32.dll
                        avrt.dllMultimedia Realtime RuntimeMicrosoft CorporationC:\Windows\System32\avrt.dll
                        AXE8SharedExpat.dllAXE Shared EXPAT (UTF-8 native)Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AXE8SharedExpat.dll
                        AXEDOMCore.dllAdobe XML Engine: DOM CoreAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AXEDOMCore.dll
                        bcrypt.dllWindows Cryptographic Primitives LibraryMicrosoft CorporationC:\Windows\System32\bcrypt.dll
                        bcryptprimitives.dllWindows Cryptographic Primitives LibraryMicrosoft CorporationC:\Windows\System32\bcryptprimitives.dll
                        BIB.dllBravo Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\BIB.dll
                        BIBUtils.dllBravo Interface Binder UtilitiesAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\BIBUtils.dll
                        boost_date_time.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_date_time.dll
                        boost_filesystem.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_filesystem.dll
                        boost_program_options.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_program_options.dll
                        boost_regex.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_regex.dll
                        boost_signals.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_signals.dll
                        boost_system.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_system.dll
                        boost_threads.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_threads.dll
                        C_20127.NLSC:\Windows\System32\C_20127.NLS
                        C_932.NLSC:\Windows\System32\C_932.NLS
                        C_936.NLSC:\Windows\System32\C_936.NLS
                        C_949.NLSC:\Windows\System32\C_949.NLS
                        C_950.NLSC:\Windows\System32\C_950.NLS
                        cfgmgr32.dllConfiguration Manager DLLMicrosoft CorporationC:\Windows\System32\cfgmgr32.dll
                        Character Animator.exeCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Character Animator.exe
                        clbcatq.dllCOM+ Configuration CatalogMicrosoft CorporationC:\Windows\System32\clbcatq.dll
                        combase.dllMicrosoft COM for WindowsMicrosoft CorporationC:\Windows\System32\combase.dll
                        comctl32.dllUser Experience Controls LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.14393.447_ none_0d5aa7fbb6d35646\comctl32.dll
                        comctl32.dllUser Experience Controls LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_n one_42191651c6827bb3\comctl32.dll
                        comdlg32.dllCommon Dialogs DLLMicrosoft CorporationC:\Windows\System32\comdlg32.dll
                        concrt140.dllMicrosoft® Concurrency Runtime LibraryMicrosoft CorporationC:\Windows\System32\concrt140.dll
                        CoolType.dllCoolType Typography EngineAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\CoolType.dll
                        counters.datC:\Users\Patrick\AppData\Local\Microsoft\Windows\INetCache\counters.dat
                        crypt32.dllCrypto API32Microsoft CorporationC:\Windows\System32\crypt32.dll
                        cryptbase.dllBase cryptographic API DLLMicrosoft CorporationC:\Windows\System32\cryptbase.dll
                        cryptnet.dllCrypto Network Related APIMicrosoft CorporationC:\Windows\System32\cryptnet.dll
                        cryptsp.dllCryptographic Service Provider APIMicrosoft CorporationC:\Windows\System32\cryptsp.dll
                        d2d1.dllMicrosoft D2D LibraryMicrosoft CorporationC:\Windows\System32\d2d1.dll
                        d3d11.dllDirect3D 11 RuntimeMicrosoft CorporationC:\Windows\System32\d3d11.dll
                        DataExchange.dllData exchangeMicrosoft CorporationC:\Windows\System32\DataExchange.dll
                        dbghelp.dllWindows Image HelperMicrosoftC:\Windows\System32\dbghelp.dll
                        dciman32.dllDCI ManagerMicrosoft CorporationC:\Windows\System32\dciman32.dll
                        dcomp.dllMicrosoft DirectComposition LibraryMicrosoft CorporationC:\Windows\System32\dcomp.dll
                        ddraw.dllMicrosoft DirectDrawMicrosoft CorporationC:\Windows\System32\ddraw.dll
                        devenum.dllDevice enumeration.Microsoft CorporationC:\Windows\System32\devenum.dll
                        devobj.dllDevice Information Set DLLMicrosoft CorporationC:\Windows\System32\devobj.dll
                        dnsapi.dllDNS Client API DLLMicrosoft CorporationC:\Windows\System32\dnsapi.dll
                        dpapi.dllData Protection APIMicrosoft CorporationC:\Windows\System32\dpapi.dll
                        dsound.dllDirectSoundMicrosoft CorporationC:\Windows\System32\dsound.dll
                        dsound.dll.muiDirectSoundMicrosoft CorporationC:\Windows\System32\en-US\dsound.dll.mui
                        dvaaccelerate.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaccelerate.dll
                        dvaadameve.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaadameve.dll
                        dvaaudiodevice.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodevice.dll
                        dvaaudiodeviceui.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodeviceui.dll
                        dvaaudiodsp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodsp.dll
                        dvaaudiofilterhost.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiofilterhost.dll
                        dvaaudiofilters.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiofilters.dll
                        dvacore.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvacore.dll
                        dvalua.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvalua.dll
                        dvamarshal.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvamarshal.dll
                        dvamediatypes.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvamediatypes.dll
                        dvametadata.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvametadata.dll
                        dvanet.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvanet.dll
                        dvaplayer.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaplayer.dll
                        dvaspeech.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaspeech.dll
                        dvatemporalxmp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvatemporalxmp.dll
                        dvatransport.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvatransport.dll
                        dvaui.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaui.dll
                        dvaundo.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaundo.dll
                        dvaunittesting.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaunittesting.dll
                        dvaworkspace.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaworkspace.dll
                        dwmapi.dllMicrosoft Desktop Window Manager APIMicrosoft CorporationC:\Windows\System32\dwmapi.dll
                        DWrite.dllMicrosoft DirectX Typography ServicesMicrosoft CorporationC:\Windows\System32\DWrite.dll
                        dxgi.dllDirectX Graphics InfrastructureMicrosoft CorporationC:\Windows\System32\dxgi.dll
                        dynamiclink.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dynamiclink.dll
                        exo.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\exo.dll
                        fastprox.dllWMI Custom MarshallerMicrosoft CorporationC:\Windows\System32\wbem\fastprox.dll
                        FWPUCLNT.DLLFWP/IPsec User-Mode APIMicrosoft CorporationC:\Windows\System32\FWPUCLNT.DLL
                        gdi32.dllGDI Client DLLMicrosoft CorporationC:\Windows\System32\gdi32.dll
                        gdi32full.dllGDI Client DLLMicrosoft CorporationC:\Windows\System32\gdi32full.dll
                        GdiPlus.dllMicrosoft GDI+Microsoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.14393.321_none_72fe 05dd211a5fae\GdiPlus.dll
                        git2.dlllibgit2 - the Git linkable libraryC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\git2.dll
                        glu32.dllOpenGL Utility Library DLLMicrosoft CorporationC:\Windows\System32\glu32.dll
                        icudt40.dllICU Data DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icudt40.dll
                        icui18n.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icui18n.dll
                        icuin40.dllIBM ICU I18N DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuin40.dll
                        icuuc.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuuc.dll
                        icuuc40.dllIBM ICU Common DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuuc40.dll
                        iertutil.dllRun time utility for Internet ExplorerMicrosoft CorporationC:\Windows\System32\iertutil.dll
                        ig9icd64.dllOpenGL(R) Driver for Intel(R) Graphics AcceleratorIntel CorporationC:\Windows\System32\ig9icd64.dll
                        igc64.dllIntel Graphics Shader Compiler for Intel(R) Graphics AcceleratorIntel CorporationC:\Windows\System32\igc64.dll
                        imm32.dllMulti-User Windows IMM32 API Client DLLMicrosoft CorporationC:\Windows\System32\imm32.dll
                        InkObjCore.dllMicrosoft Tablet PC Ink Platform ComponentMicrosoft CorporationC:\Windows\System32\InkObjCore.dll
                        input.dllInputSetting DLLMicrosoft CorporationC:\Windows\System32\input.dll
                        IPHLPAPI.DLLIP Helper APIMicrosoft CorporationC:\Windows\System32\IPHLPAPI.DLL
                        iZotope_Omega_x64.dlliZotope OmegaiZotope, Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\iZotope_Omega_x64.dll
                        iZotope_Radius_x64.dlliZotope RadiusiZotope, Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\iZotope_Radius_x64.dll
                        JP2KLib.dllAdobe JPEG2000 Core LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\JP2KLib.dll
                        kernel.appcore.dllAppModel API HostMicrosoft CorporationC:\Windows\System32\kernel.appcore.dll
                        kernel32.dllWindows NT BASE API Client DLLMicrosoft CorporationC:\Windows\System32\kernel32.dll
                        KernelBase.dllWindows NT BASE API Client DLLMicrosoft CorporationC:\Windows\System32\KernelBase.dll
                        ksuser.dllUser CSA LibraryMicrosoft CorporationC:\Windows\System32\ksuser.dll
                        libmmd.dllMath Library for Intel(r) Compilers (thread-safe)Intel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\libmmd.dll
                        libzip.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\libzip.dll
                        locale.nlsC:\Windows\System32\locale.nls
                        LogSession.dllLogSessionAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\LogSession.dll
                        mdnsNSP.dllBonjour Namespace ProviderApple Inc.C:\Program Files\Bonjour\mdnsNSP.dll
                        midimap.dllMicrosoft MIDI MapperMicrosoft CorporationC:\Windows\System32\midimap.dll
                        mkl_core.dllIntel® Math Kernel LibraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\mkl_core.dll
                        mkl_sequential.dllIntel® Math Kernel LibraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\mkl_sequential.dll
                        MMDevAPI.dllMMDevice APIMicrosoft CorporationC:\Windows\System32\MMDevAPI.dll
                        MMDevAPI.dll.muiMMDevice APIMicrosoft CorporationC:\Windows\System32\en-US\MMDevAPI.dll.mui
                        mpr.dllMultiple Provider Router DLLMicrosoft CorporationC:\Windows\System32\mpr.dll
                        MPS.dllModular Parsing SystemAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\MPS.dll
                        msacm32.dllMicrosoft ACM Audio FilterMicrosoft CorporationC:\Windows\System32\msacm32.dll
                        msacm32.drvMicrosoft Sound MapperMicrosoft CorporationC:\Windows\System32\msacm32.drv
                        msasn1.dllASN.1 Runtime APIsMicrosoft CorporationC:\Windows\System32\msasn1.dll
                        msctf.dllMSCTF Server DLLMicrosoft CorporationC:\Windows\System32\msctf.dll
                        msdmo.dllDMO RuntimeMicrosoft CorporationC:\Windows\System32\msdmo.dll
                        msi.dllWindows InstallerMicrosoft CorporationC:\Windows\System32\msi.dll
                        mskeyprotect.dllMicrosoft Key Protection ProviderMicrosoft CorporationC:\Windows\System32\mskeyprotect.dll
                        msvcp_win.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp_win.dll
                        msvcp100.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp100.dll
                        msvcp120.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp120.dll
                        msvcp140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp140.dll
                        msvcr100.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcr100.dll
                        msvcr120.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcr120.dll
                        msvcr90.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9247_none_08e394a1a8 3e212f\msvcr90.dll
                        msvcrt.dllWindows NT CRT DLLMicrosoft CorporationC:\Windows\System32\msvcrt.dll
                        msvfw32.dllMicrosoft Video for Windows DLLMicrosoft CorporationC:\Windows\System32\msvfw32.dll
                        msvfw32.dll.muiMicrosoft Video for Windows DLLMicrosoft CorporationC:\Windows\System32\en-US\msvfw32.dll.mui
                        mswsock.dllMicrosoft Windows Sockets 2.0 Service ProviderMicrosoft CorporationC:\Windows\System32\mswsock.dll
                        msxml3.dllMSXML 3.0Microsoft CorporationC:\Windows\System32\msxml3.dll
                        msxml3r.dllXML ResourcesMicrosoft CorporationC:\Windows\System32\msxml3r.dll
                        ncrypt.dllWindows NCrypt RouterMicrosoft CorporationC:\Windows\System32\ncrypt.dll
                        ncryptsslp.dllMicrosoft SChannel ProviderMicrosoft CorporationC:\Windows\System32\ncryptsslp.dll
                        netapi32.dllNet Win32 API DLLMicrosoft CorporationC:\Windows\System32\netapi32.dll
                        netutils.dllNet Win32 API Helpers DLLMicrosoft CorporationC:\Windows\System32\netutils.dll
                        normnfc.nlsC:\Windows\System32\normnfc.nls
                        nsi.dllNSI User-mode interface DLLMicrosoft CorporationC:\Windows\System32\nsi.dll
                        ntasn1.dllMicrosoft ASN.1 APIMicrosoft CorporationC:\Windows\System32\ntasn1.dll
                        ntdll.dllNT Layer DLLMicrosoft CorporationC:\Windows\System32\ntdll.dll
                        ntmarta.dllWindows NT MARTA providerMicrosoft CorporationC:\Windows\System32\ntmarta.dll
                        ole32.dllMicrosoft OLE for WindowsMicrosoft CorporationC:\Windows\System32\ole32.dll
                        oleaut32.dllOLEAUT32.DLLMicrosoft CorporationC:\Windows\System32\oleaut32.dll
                        OnDemandConnRouteHelper.dllOn Demand Connctiond Route HelperMicrosoft CorporationC:\Windows\System32\OnDemandConnRouteHelper.dll
                        opencv_calib3d2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_calib3d2413.dll
                        opencv_core2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_core2413.dll
                        opencv_features2d2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_features2d2413.dll
                        opencv_flann2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_flann2413.dll
                        opencv_highgui2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_highgui2413.dll
                        opencv_imgproc2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_imgproc2413.dll
                        opencv_objdetect2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_objdetect2413.dll
                        opencv_video2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_video2413.dll
                        opengl32.dllOpenGL Client DLLMicrosoft CorporationC:\Windows\System32\opengl32.dll
                        pdfport.dllPDFPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\pdfport.dll
                        powrprof.dllPower Profile Helper DLLMicrosoft CorporationC:\Windows\System32\powrprof.dll
                        profapi.dllUser Profile Basic APIMicrosoft CorporationC:\Windows\System32\profapi.dll
                        propsys.dllMicrosoft Property SystemMicrosoft CorporationC:\Windows\System32\propsys.dll
                        psapi.dllProcess Status HelperMicrosoft CorporationC:\Windows\System32\psapi.dll
                        PuppetWarp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\PuppetWarp.dll
                        quartz.dllDirectShow Runtime.Microsoft CorporationC:\Windows\System32\quartz.dll
                        R00000000000d.clbC:\Windows\Registration\R00000000000d.clb
                        rasadhlp.dllRemote Access AutoDial HelperMicrosoft CorporationC:\Windows\System32\rasadhlp.dll
                        RigDynamics.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\RigDynamics.dll
                        rpcrt4.dllRemote Procedure Call RuntimeMicrosoft CorporationC:\Windows\System32\rpcrt4.dll
                        rsaenh.dllMicrosoft Enhanced Cryptographic ProviderMicrosoft CorporationC:\Windows\System32\rsaenh.dll
                        schannel.dllTLS / SSL Security ProviderMicrosoft CorporationC:\Windows\System32\schannel.dll
                        sechost.dllHost for SCM/SDDL/LSA Lookup APIsMicrosoft CorporationC:\Windows\System32\sechost.dll
                        setupapi.dllWindows Setup APIMicrosoft CorporationC:\Windows\System32\setupapi.dll
                        SHCore.dllSHCOREMicrosoft CorporationC:\Windows\System32\SHCore.dll
                        shell32.dllWindows Shell Common DllMicrosoft CorporationC:\Windows\System32\shell32.dll
                        shlwapi.dllShell Light-weight Utility LibraryMicrosoft CorporationC:\Windows\System32\shlwapi.dll
                        SortDefault.nlsC:\Windows\Globalization\Sorting\SortDefault.nls
                        SPBasic.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SPBasic.dll
                        sspicli.dllSecurity Support Provider InterfaceMicrosoft CorporationC:\Windows\System32\sspicli.dll
                        StaticCache.datC:\Windows\Fonts\StaticCache.dat
                        taskschd.dllTask Scheduler COM APIMicrosoft CorporationC:\Windows\System32\taskschd.dll
                        tbb.dllThreading Building Blocks libraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\tbb.dll
                        tbbmalloc.dllScalable Allocator libraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\tbbmalloc.dll
                        twinapi.appcore.dlltwinapi.appcoreMicrosoft CorporationC:\Windows\System32\twinapi.appcore.dll
                        ucrtbase.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\ucrtbase.dll
                        updaternotifications.dllAdobe Updater Notifications LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\updaternotifications.dll
                        urlmon.dllOLE32 Extensions for Win32Microsoft CorporationC:\Windows\System32\urlmon.dll
                        user32.dllMulti-User Windows USER API Client DLLMicrosoft CorporationC:\Windows\System32\user32.dll
                        userenv.dllUserenvMicrosoft CorporationC:\Windows\System32\userenv.dll
                        uxtheme.dllMicrosoft UxTheme LibraryMicrosoft CorporationC:\Windows\System32\uxtheme.dll
                        v8.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\v8.dll
                        vcruntime140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\vcruntime140.dll
                        version.dllVersion Checking and File Installation LibrariesMicrosoft CorporationC:\Windows\System32\version.dll
                        WacomMT.dllWacom Mutli-Touch APIWacom Technology, Corp.C:\Windows\System32\WacomMT.dll
                        wbemcomn.dllWMIMicrosoft CorporationC:\Windows\System32\wbemcomn.dll
                        wbemprox.dllWMIMicrosoft CorporationC:\Windows\System32\wbem\wbemprox.dll
                        wbemsvc.dllWMIMicrosoft CorporationC:\Windows\System32\wbem\wbemsvc.dll
                        wdmaud.drvWinmm  audio system driverMicrosoft CorporationC:\Windows\System32\wdmaud.drv
                        wdmaud.drv.muiWinmm  audio system driverMicrosoft CorporationC:\Windows\System32\en-US\wdmaud.drv.mui
                        webio.dllWeb Transfer Protocols APIMicrosoft CorporationC:\Windows\System32\webio.dll
                        win32u.dllWin32uMicrosoft CorporationC:\Windows\System32\win32u.dll
                        windows.storage.dllMicrosoft WinRT Storage APIMicrosoft CorporationC:\Windows\System32\windows.storage.dll
                        Windows.UI.dllWindows Runtime UI Foundation DLLMicrosoft CorporationC:\Windows\System32\Windows.UI.dll
                        Windows.UI.Input.Inking.dllWinRT Windows Inking DLLMicrosoft CorporationC:\Windows\System32\Windows.UI.Input.Inking.dll
                        WindowsCodecs.dllMicrosoft Windows Codecs LibraryMicrosoft CorporationC:\Windows\System32\WindowsCodecs.dll
                        winhttp.dllWindows HTTP ServicesMicrosoft CorporationC:\Windows\System32\winhttp.dll
                        wininet.dllInternet Extensions for Win32Microsoft CorporationC:\Windows\System32\wininet.dll
                        winmm.dllMCI API DLLMicrosoft CorporationC:\Windows\System32\winmm.dll
                        winmmbase.dllBase Multimedia Extension API DLLMicrosoft CorporationC:\Windows\System32\winmmbase.dll
                        winnlsres.dllNLSBuild resource DLLMicrosoft CorporationC:\Windows\System32\winnlsres.dll
                        winnlsres.dll.muiNLSBuild resource DLLMicrosoft CorporationC:\Windows\System32\en-US\winnlsres.dll.mui
                        winnsi.dllNetwork Store Information RPC interfaceMicrosoft CorporationC:\Windows\System32\winnsi.dll
                        winspool.drvWindows Spooler DriverMicrosoft CorporationC:\Windows\System32\winspool.drv
                        wintrust.dllMicrosoft Trust Verification APIsMicrosoft CorporationC:\Windows\System32\wintrust.dll
                        WinTypes.dllWindows Base Types DLLMicrosoft CorporationC:\Windows\System32\WinTypes.dll
                        wkscli.dllWorkstation Service Client DLLMicrosoft CorporationC:\Windows\System32\wkscli.dll
                        WP-SymbolC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\typesupport\cmaps\WP-Symbol
                        wrservices.dllWRServices EngineWinSoft S.A.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\wrservices.dll
                        ws2_32.dllWindows Socket 2.0 32-Bit DLLMicrosoft CorporationC:\Windows\System32\ws2_32.dll
                        wship6.dllWinsock2 Helper DLL (TL/IPv6)Microsoft CorporationC:\Windows\System32\wship6.dll
                        wshqos.dllQoS Winsock2 Helper DLLMicrosoft CorporationC:\Windows\System32\wshqos.dll
                        WSHTCPIP.DLLWinsock2 Helper DLL (TL/IPv4)Microsoft CorporationC:\Windows\System32\WSHTCPIP.DLL
                        wsock32.dllWindows Socket 32-Bit DLLMicrosoft CorporationC:\Windows\System32\wsock32.dll
                        wtsapi32.dllWindows Remote Desktop Session Host Server SDK APIsMicrosoft CorporationC:\Windows\System32\wtsapi32.dll
                        xerces-c_3_0.dllShared Library for Xerces-C++ Version 3.0.0Apache Software FoundationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\xerces-c_3_0.dll
                        xmllite.dllMicrosoft XmlLite LibraryMicrosoft CorporationC:\Windows\System32\xmllite.dll
                        • 9. Re: Adobe character animator internal error code assertion failed!
                          simrick Level 1
                          That's what It give me for all .dlls for Character Animator.exe
                          • 10. Re: Adobe character animator internal error code assertion failed!
                            Hmm. I don't see anything surprising in there. Is that before or after you hit the error? One thing I'm wondering is if when Illustrator initializes it might be loading other libraries (plugins) that might explain the difference in behavior you're seeing.
                            If that's not it, I'm going to have to think a bit on how to get more clues to track down how the locale is getting reset.
                            DT
                            • 11. Re: Adobe character animator internal error code assertion failed!
                              simrick Level 1
                              that was before, this is after and I'm fairly sure that I don't use any plugins for adobe
                              System Idle Process93.210 K4 K0
                              System0.22128 K136 K4
                              Interrupts0.220 K0 Kn/aHardware Interrupts and DPCs
                              smss.exe376 K1,016 K528
                              Memory Compression196 K62,676 K3552
                              csrss.exe< 0.011,704 K4,220 K712
                              services.exe3,708 K7,616 K920
                                svchost.exe< 0.019,720 K24,540 K104Host Process for Windows ServicesMicrosoft Corporation
                                 unsecapp.exe1,628 K6,612 K3940
                                 WmiPrvSE.exe3,928 K13,052 K4212
                                 RuntimeBroker.exe33,832 K91,952 K5900Runtime BrokerMicrosoft Corporation
                                 ShellExperienceHost.exeSuspended33,020 K73,904 K6244Windows Shell Experience HostMicrosoft Corporation
                                 SkypeHost.exe0.0237,196 K65,368 K7056Microsoft Skype PreviewMicrosoft Corporation
                                 RemindersServer.exeSuspended10,116 K19,796 K7140Reminders WinRT OOP ServerMicrosoft Corporation
                                 SettingSyncHost.exe19,800 K4,732 K5604Host Process for Setting SynchronizationMicrosoft Corporation
                                 unsecapp.exe4,940 K10,180 K9528Sink to receive asynchronous callbacks for WMI client applicationMicrosoft Corporation
                                 nvspcaps64.exe0.0110,956 K30,376 K10076NVIDIA Capture ServerNVIDIA Corporation
                                  NVIDIA Share.exe< 0.0121,748 K36,456 K9508NVIDIA ShareNVIDIA Corporation
                                   NVIDIA Share.exe42,244 K54,764 K6732NVIDIA ShareNVIDIA Corporation
                                 dllhost.exe6,868 K13,108 K6932COM SurrogateMicrosoft Corporation
                                 ApplicationFrameHost.exe24,780 K38,708 K9296Application Frame HostMicrosoft Corporation
                                 SkypeApp.exe0.3037,400 K95,152 K9012SkypeAppMicrosoft
                                 SystemSettings.exeSuspended13,200 K43,736 K14644SettingsMicrosoft Corporation
                                 InputPersonalization.exe8,908 K26,068 K15236Input Personalization ServerMicrosoft Corporation
                                 Microsoft.Photos.exeSuspended118,136 K177,180 K1044
                                 SearchUI.exeSuspended43,328 K96,680 K11652Search and Cortana applicationMicrosoft Corporation
                                 Video.UI.exeSuspended14,404 K27,032 K3356Video ApplicationMicrosoft Corporation
                                 smartscreen.exe8,496 K14,860 K10436SmartScreenMicrosoft Corporation
                                 WmiPrvSE.exe< 0.013,720 K10,684 K10332
                                svchost.exe< 0.016,696 K12,016 K396Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe7,292 K20,168 K620Host Process for Windows ServicesMicrosoft Corporation
                                 dasHost.exe3,316 K11,596 K2296
                                svchost.exe< 0.0114,420 K27,304 K840Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe0.0123,208 K55,672 K1176Host Process for Windows ServicesMicrosoft Corporation
                                 sihost.exe12,080 K33,640 K6600Shell Infrastructure HostMicrosoft Corporation
                                 taskhostw.exe11,480 K22,776 K6508Host Process for Windows TasksMicrosoft Corporation
                                 SynTPEnh.exe< 0.019,296 K6,968 K6500Synaptics TouchPad 64-bit EnhancementsSynaptics Incorporated
                                 muachost.exe1,976 K1,124 K6820
                                 taskhostw.exe4,848 K14,196 K11272
                                WRSA.exe0.1134,328 K8,328 K1248Webroot SecureAnywhereWebroot
                                 WRSA.exe0.0310,196 K500 K6952Webroot SecureAnywhereWebroot
                                svchost.exe23,032 K36,412 K1316Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe12,860 K30,212 K1436Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe< 0.017,360 K18,120 K1532Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe< 0.014,184 K11,964 K1760Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe2,684 K10,120 K1976Host Process for Windows ServicesMicrosoft Corporation
                                 audiodg.exe7,160 K12,204 K13040
                                svchost.exe3,964 K13,240 K1340Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe6,376 K17,856 K2092Host Process for Windows ServicesMicrosoft Corporation
                                 wlanext.exe5,132 K16,532 K2452
                                  conhost.exe1,152 K4,984 K2468
                                AvastSvc.exe< 0.0186,180 K40,740 K2212avast! ServiceAVAST Software
                                svchost.exe< 0.014,244 K13,256 K2232Host Process for Windows ServicesMicrosoft Corporation
                                spoolsv.exe< 0.015,948 K14,744 K2600Spooler SubSystem AppMicrosoft Corporation
                                svchost.exe< 0.0117,412 K35,992 K3024Host Process for Windows ServicesMicrosoft Corporation
                                EvtEng.exe5,072 K13,612 K2056Intel(R) PROSet/Wireless Event Log ServiceIntel(R) Corporation
                                TuneUpUtilitiesService64.exe0.0314,012 K29,884 K3156AVG PC TuneUp ServiceAVG Technologies
                                 TuneUpUtilitiesApp64.exe0.016,960 K20,692 K6656AVG PC TuneUpAVG Technologies
                                WTSrv.exe1,084 K4,860 K3164
                                 nvcontainer.exe0.0116,020 K29,304 K6676NVIDIA ContainerNVIDIA Corporation
                                MSIService.exe1,676 K8,664 K3208MSI SCM ServiceMicro-Star International Co., Ltd.
                                NVDisplay.Container.exe2,520 K9,932 K3216NVIDIA ContainerNVIDIA Corporation
                                 nvxdsync.exe< 0.019,768 K24,568 K4900
                                pnusbvirtualhubwssrv.exe< 0.011,928 K5,540 K3236Virtual USB Hub Main moduleDell Inc.
                                NvTelemetryContainer.exe< 0.016,720 K13,456 K3248NVIDIA ContainerNVIDIA Corporation
                                nvwirelesscontroller.exe2,352 K8,836 K3260NVIDIA Wireless Controller ServiceNVIDIA Corporation
                                svchost.exe2,308 K8,988 K3296Host Process for Windows ServicesMicrosoft Corporation
                                ZeroConfigService.exe4,644 K16,532 K3344Intel® PROSet/Wireless Zero Configure ServiceIntel® Corporation
                                svchost.exe7,900 K20,520 K3512Host Process for Windows ServicesMicrosoft Corporation
                                svchost.exe13,012 K41,776 K6580Host Process for Windows ServicesMicrosoft Corporation
                                SearchIndexer.exe0.0146,424 K53,768 K7028Microsoft Windows Search IndexerMicrosoft Corporation
                                 SearchProtocolHost.exe2,500 K11,636 K3100
                                 SearchFilterHost.exe1,256 K6,240 K3604
                                IAStorDataMgrSvc.exe30,044 K51,312 K11248IAStorDataSvcIntel Corporation
                                wmpnetwk.exe6,556 K2,388 K10152Windows Media Player Network Sharing ServiceMicrosoft Corporation
                                IntelCpHeciSvc.exe1,812 K7,376 K13712IntelCpHeciSvc ExecutableIntel Corporation
                                isa.exe9,280 K12,868 K3448Intel(R) Security AssistIntel Corporation
                              lsass.exe< 0.016,980 K16,964 K928Local Security Authority ProcessMicrosoft Corporation
                              csrss.exe0.282,584 K8,452 K852
                              winlogon.exe2,020 K9,636 K740
                              dwm.exe0.77106,964 K132,492 K1028
                              explorer.exe0.07133,564 K202,072 K7184Windows ExplorerMicrosoft Corporation
                              RtkNGUI64.exe8,196 K16,076 K6424Realtek HD Audio ManagerRealtek Semiconductor
                              MsiTrueColor.exe0.066,356 K15,916 K9364MSI True ColorPortrait Displays, Inc.
                              SCM.exe95,984 K101,180 K9572SCMMSI
                              OneDrive.exe< 0.0120,136 K45,464 K9840Microsoft OneDriveMicrosoft Corporation
                              flux.exe0.0117,448 K19,452 K9952f.luxFlux Software LLC
                              IDMan.exe18,584 K46,804 K10104Internet Download Manager (IDM)Tonec Inc.
                                IDMIntegrator64.exe< 0.016,836 K14,620 K1292IDM Integration moduleInternet Download Manager, Tonec Inc.
                                IEMonitor.exe1,628 K8,192 K9332Internet Download Manager agent for click monitoring in IE-based browsersTonec Inc.
                              SteelSeriesEngine3.exe< 0.0128,256 K41,376 K7240SteelSeries Engine 3 CoreSteelSeries ApS
                              MEGAsync.exe25,020 K44,000 K856MEGAsyncMega Limited
                              Rainmeter.exe2.7254,980 K79,680 K7776
                                chrome.exe0.08191,576 K256,720 K11584Google ChromeGoogle Inc.
                                 chrome.exe0.013,488 K14,872 K11664Google ChromeGoogle Inc.
                                 chrome.exe0.026,776 K18,216 K11740Google ChromeGoogle Inc.
                                 chrome.exe0.0188,660 K104,364 K11952Google ChromeGoogle Inc.
                                 chrome.exe< 0.01170,872 K174,916 K8848Google ChromeGoogle Inc.
                                 chrome.exe28,832 K37,036 K12388Google ChromeGoogle Inc.
                                 chrome.exe< 0.0164,956 K71,280 K12396Google ChromeGoogle Inc.
                                 chrome.exe< 0.01114,432 K234,096 K12596Google ChromeGoogle Inc.
                                 chrome.exe< 0.01161,516 K238,712 K13908Google ChromeGoogle Inc.
                              rundll32.exe1,480 K9,772 K2472Windows host process (Rundll32)Microsoft Corporation
                              Photoshop.exe0.203,531,608 K1,663,196 K8732Adobe Photoshop CC 2017Adobe Systems, Incorporated
                                AdobeIPCBroker.exe2,564 K9,748 K864Adobe IPC BrokerAdobe Systems Incorporated
                                Adobe Spaces Helper.exe< 0.0137,392 K58,200 K4120
                                Adobe Spaces Helper.exe49,720 K67,520 K5944
                                Adobe Spaces Helper.exe43,488 K56,760 K2684
                                node.exe44,568 K48,892 K9908Node.js: Server-side JavaScriptNode.js
                                 conhost.exe8,116 K12,892 K12224Console Window HostMicrosoft Corporation
                                CEPHtmlEngine.exe< 0.0122,040 K49,716 K1784Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe< 0.0128,088 K48,196 K1020Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe< 0.0153,800 K59,340 K11332Adobe CEP HTML EngineAdobe Systems Incorporated
                                CEPHtmlEngine.exe< 0.0111,896 K31,216 K2248Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe< 0.0123,708 K28,524 K5640Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe27,120 K35,852 K3976Adobe CEP HTML EngineAdobe Systems Incorporated
                                CCLibrary.exe436 K2,636 K8968CCLibrariesAdobe Systems Incorporated
                                 node.exe< 0.0143,728 K60,912 K3152Node.js: Server-side JavaScriptNode.js
                                  conhost.exe4,880 K9,492 K10264Console Window HostMicrosoft Corporation
                                CEPHtmlEngine.exe< 0.0111,700 K31,032 K9388Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe< 0.0123,368 K28,324 K14292Adobe CEP HTML EngineAdobe Systems Incorporated
                                 CEPHtmlEngine.exe32,744 K41,180 K13660Adobe CEP HTML EngineAdobe Systems Incorporated
                              Character Animator.exe0.40304,400 K274,816 K1220Character Animator CC BetaAdobe Systems Incorporated
                                dynamiclinkmanager.exe9,032 K17,788 K8852Adobe Dynamic Link Manager 1.0Adobe Systems Incorporated
                              procexp.exe4,216 K10,952 K3276Sysinternals Process ExplorerSysinternals - www.sysinternals.com
                                procexp64.exe1.0333,508 K69,392 K8276Sysinternals Process ExplorerSysinternals - www.sysinternals.com
                              igfxEM.exe6,292 K14,712 K7772igfxEM ModuleIntel Corporation
                              igfxHK.exe5,552 K11,820 K7876igfxHK ModuleIntel Corporation
                              igfxTray.exe5,704 K13,044 K7988
                              SynTPHelper.exe908 K748 K8888
                              AvastUI.exe0.0216,528 K27,744 K2852avast! AntivirusAVAST Software
                              ProductUpdater.exe0.0131,412 K37,952 K8224ProductUpdater
                              NVIDIA Web Helper.exe0.0331,760 K47,544 K8516NVIDIA Web Helper ServiceNode.js
                              conhost.exe4,880 K7,988 K5356Console Window HostMicrosoft Corporation
                              Process: Character Animator.exe Pid: 1220
                              {6AF0698E-D558-4F6E-9B3C-3716689AF493}.2.ver0x000000000000001b.dbC:\ProgramData\Microsoft\Windows\Caches\{6AF0698E-D558-4F6E-9B3C-3716689AF493}.2.ver0x0000 00000000001b.db
                              {DDF571F2-BE98-426D-8288-1A9A39C3FDA2}.2.ver0x0000000000000001.dbC:\ProgramData\Microsoft\Windows\Caches\{DDF571F2-BE98-426D-8288-1A9A39C3FDA2}.2.ver0x0000 000000000001.db
                              3DLib.aip3D EffectsAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\3DLib.aip
                              69b8a4a.BUDC:\Windows\System32\spool\V4Dirs\210C7759-3DEA-49B1-BDB4-71735B1C6889\69b8a4a.BUD
                              AavmRpch.dllavast! AAVM Remote Procedure Call LibraryAVAST SoftwareC:\Program Files (x86)\avast\x64\AavmRpch.dll
                              AIPort.dllAIPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AIPort.dll
                              AIRes.dllAdobe Illustrator CCAdobe Systems Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\System\AIRes.dll
                              amsi.dllAnti-Malware Scan InterfaceMicrosoft CorporationC:\Windows\System32\amsi.dll
                              ArtConverters.aipArt ConvertersAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\ArtConverters.aip
                              AssetMgmt.aipAssetMgmt PluginAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\AssetMgmt.aip
                              aswAMSI.dllAvast AMSI COM objectAVAST SoftwareC:\Program Files (x86)\avast\x64\aswAMSI.dll
                              aswCmnBS.dllCommon functionsAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnBS.dll
                              aswCmnIS.dllAntivirus independent functionsAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnIS.dll
                              aswCmnOS.dllAntivirus HW dependent libraryAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnOS.dll
                              aswProperty.dllavast! Property Storage libraryAVAST SoftwareC:\Program Files (x86)\avast\x64\aswProperty.dll
                              BeautifulStrokes.aipBeautifulStrokes SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\BeautifulStrokes.aip
                              BRSPencilTool.aipBRS Pencil ToolAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\BRSPencilTool.aip
                              BrushManager.aipBrush ManagerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\BrushManager.aip
                              cversions.2.dbC:\ProgramData\Microsoft\Windows\Caches\cversions.2.db
                              dbgcore.dllWindows Core Debugging HelpersMicrosoftC:\Windows\System32\dbgcore.dll
                              Deform.aipEnvelope and WarpAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Deform.aip
                              DiffusionRasterSuite.aipDiffusion RasterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\DiffusionRasterSuite.aip
                              edputil.dllEDP utilMicrosoft CorporationC:\Windows\System32\edputil.dll
                              ExpandS.aipExpand SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\ExpandS.aip
                              FilterPort.dllFilterPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\FilterPort.dll
                              FOConversionSuite.aipFO Conversion SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\FOConversionSuite.aip
                              FrameworkS.aipFWServerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\FrameworkS.aip
                              FuzzyEffect.aipFuzzy EffectAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\FuzzyEffect.aip
                              jscript.dllMicrosoft ® JScriptMicrosoft CorporationC:\Windows\System32\jscript.dll
                              log.dllAvast Logging LibraryAVAST SoftwareC:\Program Files (x86)\avast\x64\log.dll
                              MPSCommon.aipMPSCommonAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Formats\MPSCommon.aip
                              mscms.dllMicrosoft Color Matching System DLLMicrosoft CorporationC:\Windows\System32\mscms.dll
                              MSOXMLMF.DLLMicrosoft Office XML MIME FilterMicrosoft CorporationC:\Program Files\Common Files\microsoft shared\OFFICE15\MSOXMLMF.DLL
                              msvcp140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_56aba0211ca246c 2\msvcp140.dll
                              msxml6.dllMSXML 6.0Microsoft CorporationC:\Windows\System32\msxml6.dll
                              msxml6r.dllXML ResourcesMicrosoft CorporationC:\Windows\System32\msxml6r.dll
                              MXDWDRV.DLLMicrosoft XPS Document WriterMicrosoft CorporationC:\Windows\System32\DriverStore\FileRepository\ntprint.inf_amd64_7b3eed059f4c3e41\Amd64\MX DWDRV.DLL
                              OpcServices.dllNative Code OPC Services LibraryMicrosoft CorporationC:\Windows\System32\OpcServices.dll
                              Pathfinder.aipPathfinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Pathfinder.aip
                              PathfinderS.aipPathfinder SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PathfinderS.aip
                              PathSuite.aipPath Construction SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\PathSuite.aip
                              PDFFormat.aipPDF FormatAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PDFFormat.aip
                              PDFSuite.aipPDF SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PDFSuite.aip
                              PhotoshopAdapter.aipPhotoshop Plug-in AdapterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\PhotoshopAdapter.aip
                              PrintConfig.dllPrintConfig User InterfaceMicrosoft CorporationC:\Windows\System32\DriverStore\FileRepository\prnms003.inf_amd64_be4393c143e46548\Amd64\P rintConfig.dll
                              prntvpt.dllPrint Ticket Services ModuleMicrosoft CorporationC:\Windows\System32\prntvpt.dll
                              prntvpt.dll.muiPrint Ticket Services ModuleMicrosoft CorporationC:\Windows\System32\en-US\prntvpt.dll.mui
                              PSImport.aipPhotoshop File Import FilterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Formats\PSImport.aip
                              Rasterize.aipRasterizeAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\Rasterize.aip
                              stdole2.tlbSTDOLE2.TLBMicrosoft CorporationC:\Windows\System32\stdole2.tlb
                              SVGExport.dllSVGExport 6.0Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SVGExport.dll
                              svgFileFormat.aipSVG File FormatAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\svgFileFormat.aip
                              SVGFilterEffect.aipSVG Filter EffectAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\SVGFilterEffect.aip
                              SVGRE.dllSVGRE 6.0Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SVGRE.dll
                              sxs.dllFusion 2.5Microsoft CorporationC:\Windows\System32\sxs.dll
                              Transform.aipTransform EachAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Transform.aip
                              vcruntime140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_56aba0211ca246c 2\vcruntime140.dll
                              xpsservices.dllXps Object Model in memory creation and deserializationMicrosoft CorporationC:\Windows\System32\xpsservices.dll
                              • 12. Re: Adobe character animator internal error code assertion failed!
                                Ok, I had a chance to peruse these and compare with my own DLL lists. There are a few differences, but the most noteworthy  difference in what your machine loaded in the after list versus mine was a bunch of DLLs for Avast Anti-virus, including a DLL that appears to be from Avast but has the name vcruntime140.dll (the main C runtime DLL from Microsoft), which seems weird (though anti-virus programs often are, partially by necessity, rather invasive).
                                I'll need to look around a bit, but at the moment that's my prime suspect.
                                DT
                                • 13. Re: Adobe character animator internal error code assertion failed!
                                  I installed the free version of Avast in my VM and I'm still not seeing those extra DLLs being injected into Character Animator as your DLL lists show. I'm not sure if those are due to an option I don't have enabled or some other difference.
                                  DT
                                  • 14. Re: Adobe character animator internal error code assertion failed!
                                    simrick Level 1
                                    That's odd? should i try and uninstall Avast just to see if it works? I'm only using the the free one aswell
                                    • 15. Re: Adobe character animator internal error code assertion failed!
                                      It would be an useful experiment if you're willing to try it.
                                      DT
                                      1 person found this helpful
                                      • 16. Re: Adobe character animator internal error code assertion failed!
                                        simrick Level 1
                                        Your not going to believe this dude but it worked! I restarted my computer after I uninstalled it I it works fine now with illustrator.
                                        • 17. Re: Adobe character animator internal error code assertion failed!
                                          Wow. I mean Avast was my number one suspect, but I'm still slightly surprised that smoking gun really turned out to be the murder weapon (so to speak). I did still add some bullet-proofing on our side to make us more resilient to this situation, but I'm really glad that it fixed your situation.
                                          DT
