Windows 7 + Dreanweaver CC (2017.0.1 9346 ビルド) 環境で Compass を使用する際、.sass で @Import "compass"; を記述するとインポートできずにエラーになります。
@Import "compass/reset"; は OK です。
以下はエラーメッセージ。
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/(my home)/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170120-5944-aqqlcs
Macos Sierra + Dreanweaver CC 環境では、上記エラーは発生していないので、 Windows 7 環境での問題と考えています。
何か解決策をありますか?
Not the exact answer to your question, but I want to make sure that you are following the procedure mentioned in this document.
See, "Using the compass framework" in Using CSS preprocessors in Dreamweaver
Preran
I have read "Using CSS preprocessors in Dreamweaver". So, I have tried to make my new test site with the instructions in it. But, just found the same error.
See config.rb, screen.scss, screen.css:
Takeomi
-- config.rb
require 'compass/import-once/activate'
# Require any additional compass plugins here.
# Set this to the root of your project when deployed:
http_path = "/"
css_dir = "stylesheets"
sass_dir = "sass"
images_dir = "images"
javascripts_dir = "javascripts"
# You can select your preferred output style here (can be overridden via the command line):
# output_style = :expanded or :nested or :compact or :compressed
# To enable relative paths to assets via compass helper functions. Uncomment:
# relative_assets = true
# To disable debugging comments that display the original location of your selectors. Uncomment:
# line_comments = false
# If you prefer the indented syntax, you might want to regenerate this
# project again passing --syntax sass, or you can uncomment this:
# preferred_syntax = :sass
# and then run:
# sass-convert -R --from scss --to sass sass scss && rm -rf sass && mv scss sass
-- sass/screen.scss
@import "compass";
body {
background-color: #fff;
-- stylesheets/creen.css
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170123-12964-b3ufpm
Backtrace:
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `open'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `block in initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tmpdir.rb:129:in `create'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:133:in `initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `new'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `atomic_create_and_write_file'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/filesystem.rb:39:in `_store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/base.rb:51:in `store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `block in store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `each'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:414:in `_to_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:309:in `to_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:324:in `block in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `block in with_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:115:in `with_frame'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `with_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:323:in `visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `block in visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `block in with_base'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `with_base'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block (2 levels) in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `map'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `block in visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `map'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:167:in `block in visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:179:in `with_environment'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:166:in `visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `block in visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:186:in `visit_root'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:157:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:8:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:36:in `css_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:20:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:278:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:17:in `block in render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:29:in `with_import_scope'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:16:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:492:in `update_stylesheet'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:215:in `block in update_stylesheets'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `each'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `update_stylesheets'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/sass_compiler.rb:40:in `compile!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/update_project.rb:49:in `perform'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/base.rb:18:in `execute'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/project_base.rb:19:in `execute'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:43:in `perform!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:15:in `run!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:30:in `block in <top (required)>'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `call'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `<top (required)>'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `load'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `<main>'
body:before {
white-space: pre;
font-family: monospace;
content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170123-12964-b3ufpm"; }
Please show us the contents of config.rb
Is config.rb located in the root directory of your site?
Is the location of config.rb specified in Site Setup?
Perhaps I should have asked the most important question first, namely do need Compass or can you do without. See here for more info Why I Don't Use Compass Anymore
If you do not need Compass, then the problem is solved.
Edit:
I do use Compass only to create my image sprites and have no problem with it. However, I will be moving away from that soon preferring to use SVG's equivalent. After that, I will have no use for Compass.
Here:
-- config.rb
http_path = "/"
sass_dir = "sass"
# and then run:
Yes.
Yes.
> Edit:
Yes, I need Compass for now.
I have read your "info Why I Don't Use Compass Anymore". I partially agree.
I'm using Compss on Windws 7 + Cygwin + cygwin ruby gem + Compass with many Compass mixin. It's not bad. But, my Web team members are not familiar with Cygwin, ruby, gem. So, I'm going to change our development environment from Cygwin + Compass to DW + Compass. I's more simpe for my Web team members.
Takeomi
Change
http_path = "/"
sass_dir = "sass"
to (note the http_path link which goes below the root directory)
http_path = "../"
sass_dir = "sass"
I have chaged config.rb. But, nothing has been changed.
Thannks,
Takeomi
--- config.rb
http_path = "../"
sass_dir = "sass"
# and then run:
--- sass/screen.scss
@import "compass";
body {
--- stylesheets/screen.compass - compiled sass/screen.scss
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170124-16324-lpmam3
Backtrace:
body:before {
white-space: pre;
content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170124-16324-lpmam3"; }
I'm sorry that it still will not work. Please have a look at how I have my setup.
1. Directory structure
2. Site Setup - General
3. Site Setup - Source & Output
4. Site Setup - Compass
That's all and it works like a charm.
If, after comparing the above with your setup, you still cannot get it to work, you may like to try to un-install Dreamweaver, Use the Creative Cloud Cleaner Tool to solve installation problems and re-install Dreamweaver. Hopefully that will fix it. Fingers crossed.
