Hi.
I just installed a trial version of Adobe Photoshop 2017 to my Laptop PC to see and test out what's new with this software. I have signed-in with my Adobe ID and updated to latest version 2017.0.1 via Creative Cloud.
While I could search for Adobe Stock in stock.adobe.com (and add Preview to My Library and it would appear on my Photoshop Library), I couldn't do the search from within the Photoshop Libraries. It shows "Sorry, something went wrong while searching Adobe Stock. Please try again." error message. How do I fix this?
Cheers.
Hendra
Found the solution myself. Apparently it is incompatible with Lavasoft Ad-Aware Web Companion as a whole. The previous method of renaming the dll files fixes the Adobe Photoshop crash on load but apparently still causing issue with Adobe Stock.
I uninstalled Lavasoft Ad-Aware Web Companion and now Photoshop works as it should.
I have tried:
- reinstall
- signing out and signing in
- restart computer
I'm on Windows 10 Pro x64 Laptop.
I guess you have the Creative Cloud Desktop app installed. Is File Syncing on?
Can you also search for Stock through the Desktop app?
CC Sync is ON.
Searching through CC (the screenshot you gave), type "Piano" and press enter will open up my Chrome with this link
Piano photos, royalty-free images, graphics, vectors & videos | Adobe Stock
I suppose that's what it suppose to do?
I could click on "Save Preview to My Library" on that page and it would appear on Photoshop. But I was expecting to be able to search from within the program itself just like what I saw on a number of Youtube demo/tutorial videos.
Yes, you should be able to search inside the Library Panel, so now that I'm satisfied you have a good connection, I'll see what I can find out.
If you connect to the Adobe Stock website and click on the Libraries tab, are your Libraries listed?
Also since you are on a Trial, I'm not sure if that's a Trial limitation.
Right now I have to leave. You should also ask in the Adobe Stock forum and see if someone there may know why your Libraries Panel will not do the Search.
Yes. my libraries are listed. I even created a new library from Photoshop and it appears on that Adobe Stock website.
Curiously I just installed on a brand new computer I bought for my staff and it works there. Not sure why it doesn't work on my computer.
One thing to note is the program actually crash immediately after I open it up, but after following the fix here
Photoshop CC 2017 crashes on opening
and renamed my LavasoftTcpService64.dll to Old.LavasoftTcpService64.dll the Photoshop runs fine. This issue doesn't occur on the new install on that new computer.
Not sure if these two problems are related.
Thanks for letting us know. I knew about the Web Companion causing Ps to crash on launch, but I did not know it caused problems in the Adobe Stock search via the Library Panel.
Gene
