Hi, I would like to know how to get the current column of a paragraph in a multicolumn textframe.
Given a story myStory formed by several multicolumn textFrames along multiple pages, I can access to its textFrames, columns of the textFrames, and paragraphs and words and lines,... in that order with codes like
var myParagraph = myStory.paragraphs[a];
var myColumn = myStory.parentTextFrames[myframe].textColumns[myColumnIndex];
But I dont know in which sub column is a known paragraph or line. I wonder if exists some method or property to get it as the parent, parentTextFrame or parentStory exist for other objects. In my work I want to know if a paragraph is shared between two or more sub columns.
Thanks in advance.
In this case check givenParagraph.textColumns.length
In this case you may need to calculate it. For example in this way:
(to alert column's number of 1st paragraph of current selection)
var
arrayOfIndexes = app.selection[0].parentStory.textColumns.everyItem().index,
searchObject = app.selection[0].paragraphs[0],
cIndex, step,
searchIndex = searchObject.textColumns[0].index;
for (step = 0; step < arrayOfIndexes.length; step++) {
cIndex = arrayOfIndexes[step];
if (searchIndex == cIndex) {
alert ("searchObject found in a textColumn number: " + (step+1) );
break;
Jarek
Thanks very much, Jarek. I´m working with your code.
