Hi All,
I have taken some raw images on my drone.
When I preview the image it looks fine (below)
When i open it in Lightroom or Photoshop it appears as below with the pixelated area:
Any ideas?
Ian
GhostNeo wrote:
Every image is the same
If every image has the exact same artifact pattern that indicates a sensor defect or damage (sun burn). This was also the conclusion at the DJI forum by their tech support people.
If you're referring to the below area it looks like image data corruption. The image file looks OK outside of LR because your may be using a viewer that displays the embedded preview and not the raw image data. If the images are still on the memory card you can try downloading them again. How many images are affected like this and how are you downloading them onto your system?
Thank you,
I used lightroom to import
What model of drone are you using?
This looks similar to the issue described in this thread: https://forums.adobe.com/thread/2123774
It looks like the end user replaced the drone camera?
And there was also another thread that I can not find today that had some red/blue artifacts when using HDR mode that was fixed with drone firmware update.
-BH
