While comparing the 2 pdf older version and newer version. In Textual compare in shows text is identical, but in visual compare it showing some error. Any suggestion regarding this issue.
What error?
Acrobat DC lets one select what to display, you need to set the filter in the DC compare documents to display the same items as the older version. Changes in DC are indicated by a balloon comment.
We have done this acrobat 7 professional. I attached screenshot of error showing for your reference. But again if we done compare, the same PDF on the same machine using acrobat 7 professional. This error is not showing.
What error?
Older versions of Acrobat report changes in positon as a difference. Make sure you are using the same parameters for the searching in the 2 programs.
Acrobat 7 is very old and no longer supported by newer OSs. If you are using Windows 7,8, or 10 you might consider upgrading.
alguien que hable español
tengo problemas con la comparación de pdf
