Acrobat Xi "Find" & "Replace" discussion.
Jan 21, 2017 Jan 21, 2017
My credit card statements come with dates in the format "dd/mm/yy".
I ultimately want the transactions to be saved as an access data base file.
To do this I export the cropped PDF transactions to an XLSX file.
However XL interprets the dates as YY/MM/dd.
The solution is to "find and replace" the dates in the PDF transactions as dd/mm/yyyy.
However when I type "/16" into the find box it finds nothing because the greyed out, prechecked "find whole words only" cannot be unchecked.
Tried full acrobat search which works fine - but there is nowhere to replace wit "/2016".
I would appreciate some help if someone has an answer
Edit and convert PDFs
613
Community Expert , Jan 21, 2017 Jan 21, 2017
You may not have to do anything: In Access, on the Import dialog, there is an "Advanced" button, that brings you to a dialog for import options. Here you can specify the data format. That should allow you to prevent the problem in the first place.
Don't try to do this in the PDF file. Export the data as a plain-text file and then it will be much easier to manipulate it in such a way using a plain-text editor that supports RegExp replacements, like Notepad++.
Jan 23, 2017 Jan 23, 2017
Thank you Karl, you helped solve my problem; saved me hours of trying to find a work around.
To clarify how it works:-
1 Crop the data needed in the PDF file
2 Delete the unwanted pages
3 Export the cropped data to Excel; BUT save as HTML (Saving as XLSX is no good as the damage is already done)
4 HTML reads the date as Text
5 Access will then allow me to format the text as D/M/Y and also delete the 4 digit year.
Again, thank you very much; appreciated.
